Hello Guest it is October 23, 2026, 02:05:10 PM
Author Topic: LazyTurn  (Read 3541094 times)
0 Members and 6 Guests are viewing this topic.
Re: LazyTurn
« Reply #1290 on: February 23, 2010, 06:01:02 PM »
Getting Error 215 and 219 pretty regular now on the Joust.dxf when attempting a FINE with .001 tol.
Ran the diagnostics output with a FINE and the errors went away but the FINE path is still awry.
Russ
Re: LazyTurn
« Reply #1291 on: February 23, 2010, 07:28:55 PM »
FOR FILE IN REPLY 1287 / JOUST.DXF. Not getting any errors but fines are not right.
Re: LazyTurn
« Reply #1292 on: February 23, 2010, 07:43:45 PM »
Tried a number of different fines at or under .001 tolerance, no numbered errors.
Re: LazyTurn
« Reply #1293 on: February 23, 2010, 08:56:41 PM »
Nice documentation Rich. I get the diagonal to the centerline at the left end on occasion as well.
Here is a combo the gives me the 215 ..... three times in a row. Can you see anything obvious that I might be missing ?
Also, on occasion one error or the other would just close the dxf file and leave a fresh LT screen where other times it shuts lt down and asks for an error report.
Not sure how to duplicate 219...will try.
Thanks Rich,
Russ
Re: LazyTurn
« Reply #1294 on: February 23, 2010, 08:59:29 PM »
just for kicks...tried the same in RADIUS mode as well as DIAMETER.
Same error.
Just a shot.
Russ
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #1295 on: February 23, 2010, 09:09:28 PM »
Rich:
  No question. I didnt mean to say Ill be dropping work any time soon, in fact I hope to have posting out by next week of the finish passes.
Then a few weeks of bug fixes and perhaps undercut compensation will get done before I move to the next time slice. I dont think it will be
long before LTurn is set as Release 1.0A .
   It may not do everything people want, but it will do much better than LazyCam could do.. Till next time slice when it
will do more. :)
Art
Re: LazyTurn
« Reply #1296 on: February 23, 2010, 10:10:47 PM »
Adding this feature to the JOUST profile somehow eliminates the 215 error.
(did this to justify the .001 tol setting)
Russ
Re: LazyTurn
« Reply #1297 on: February 24, 2010, 07:36:24 AM »
Russ,
I get a 219 error with your combination shown in reply 1293 and LT shuts down then.
I don't think your missing anything as the rough and finish passes are reasonable.
Re: LazyTurn
« Reply #1298 on: February 24, 2010, 07:44:42 AM »
Art,
I'm embarrassed to bring up such a small point, but........
Before you put LT back on the shelf please remember that "Zoom in" and "Zoom out" are reversed, compared to AutoCAD.
Re: LazyTurn
« Reply #1299 on: February 24, 2010, 07:45:25 AM »
Thanks Rich.   219 ? ? ?
I get 215.
I cant produce the 219 now.
