Hello Guest it is October 24, 2026, 04:54:56 PM
Author Topic: LazyTurn  (Read 3546642 times)
Re: LazyTurn
« Reply #740 on: January 05, 2009, 11:31:18 AM »
Hi Guys:
Thx,
Art ( Just keepign you informaed.. :)  )
Sounds like a plan to me, thanks, Art-  :)
Re: LazyTurn
« Reply #741 on: January 05, 2009, 11:36:28 AM »
Tried to start the latest download, placed it into Mach3 directory with lazyturn installed but "ANN.dll not loaded"?
What can I do about this?
Kind regards,
Andre
Re: LazyTurn
« Reply #742 on: January 05, 2009, 11:42:15 AM »
Thanks Art
Sorry if my post disturb your way of thinking but i try to give a realistic image of what i think that turning is about.
Greetings:
Willem
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #743 on: January 05, 2009, 11:45:28 AM »
Hi:
 If ann.dll is not found, then you havent installed the LazyCam update before trying LTurn. Download the LCam update file and install that first.
thx
Art
Re: LazyTurn
« Reply #744 on: January 05, 2009, 12:16:45 PM »
 >:(Art,
Can you upload the update file to my emal adress.
The normal download from the site remains faulty.
Kind regards,
My email address is ahroest@xs4all.nl
Re: LazyTurn
« Reply #745 on: January 06, 2009, 12:16:01 PM »
Unfortunately is it impossible to download a working lazycam update from this site and therefore it is also impossible to use lazyturn since he misses ANN.dll
Can somebody help me by mailing a working file???
ahroest@xs4all.nl
Kind regards,
Andre
Re: LazyTurn
« Reply #746 on: January 06, 2009, 01:22:23 PM »
I just checked it and it's working just fine. Possibly give it another try?
http://www.machsupport.com/downloads/LazyCam3.00.2_Update.exe
Also sent to your email-
« Last Edit: January 06, 2009, 01:26:56 PM by budman68 »
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyTurn
« Reply #747 on: January 06, 2009, 01:39:03 PM »
Hi, Andre
I emailed the update to you a few min. ago, You'll need to rename the file I sent you.
Hears the ANN.dll Zipped up, You may be missing more than that though.
Chip
Re: LazyTurn
« Reply #748 on: January 06, 2009, 03:28:37 PM »
Hi Art
A was thinking (i do sometime), if i use a diamant of 30 degree (for example) and i would use the same feedrate in X an Z direction the tooltip Will not like to cut in X direction because the force on the tooltip is to big in relationship to the Z direction.
On the other hand, if i use a grove tool the force relationship is in the opposite direction.
What i try to say that it is almost unavoidable to give tools a parameter table (what the program can work with) if we want to use a tool in the most useful way.
Greetings:
Willem
Re: LazyTurn
« Reply #749 on: January 06, 2009, 04:36:11 PM »
Willem,
Can you explain more about the parameter table / what you mean?
