Hello Guest it is October 30, 2026, 11:31:36 AM
Author Topic: LazyTurn  (Read 3620541 times)
0 Members and 7 Guests are viewing this topic.
Re: LazyTurn
« Reply #250 on: November 13, 2008, 06:16:23 AM »
Chip,
Modified my reply #244 to add the dxf file.
I haven't paid too much attention to the portrayal of  roughing graphics to date.
Figured the file needs to import and generate a roughing cut reasonably close / in the ballpark
and leave interpretation of graphic quality up to Art for now. Don't know what to expect on the graphics at this
point. At some time it should portray only on one side, ......hey here's a cloud above my head.....
if something appears above the displayed porfile could it be used as a clue of whats wrong on the drawn profile......
If gode was generated, will back plot the gcode and compare agaisnt the original profile for just for kicks on a few.
Time for work,
Re: LazyTurn
« Reply #251 on: November 13, 2008, 08:08:53 AM »
Question:
  Where is the stock size initially described and why this error when attempting to change the stock size at the X scale ?
Also, in setting up a grooving tool, the IC appears to be the width of the tool and Radius can be zero. The length of the tool projection seems to be equal to the Holder length. More on that later.
RC
Re: LazyTurn
« Reply #252 on: November 13, 2008, 07:00:15 PM »
Art,
A few comments and errors created when using 8.dxf from post #247.
They are noted  1,2,3,4 in red in the jpg attached.
Re: LazyTurn
« Reply #253 on: November 13, 2008, 07:21:31 PM »
Art,
Her is another TODO error. Created by input of a small value for the inscribed circle.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyTurn
« Reply #254 on: November 13, 2008, 08:52:09 PM »
Hi, Rich
I found that BobCad v22 DXF's are saving as ACAD R14 "AC1014" format, LazyCam/LazyTurn seems to be happiest with AC1006 (R10) & AC1009 (R11/R12) DXF's, Thanks for posting the File.
RC: Post your dxf and check the AC # as listed above.
Thanks, Chip
Re: LazyTurn
« Reply #255 on: November 13, 2008, 09:47:02 PM »
CHIP,
Here is the DXF.
This is how I save them all.
RC
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #256 on: November 13, 2008, 11:09:20 PM »
Hi, RC
I was able to reproduce the issue hear.
If you look into it further, There seem to be an Issue with the Stock Dia, Profile Dia and Posted G-code Diameter, Values.
Final Part should be 2.00 (R 1.00 x 2=2.00), G-code shows ( R 1.3225) or 2.645 Dia., Same as Stock Dir. Shown, I Think.
Pretty, Wild, Nice & Wonderful Program
Thanks, Chip
« Last Edit: November 13, 2008, 11:18:55 PM by Chip »
Re: LazyTurn
« Reply #257 on: November 14, 2008, 08:30:24 AM »
Hi Chip,
Wild, Nice and Wonderful...I agree.
Did you try to change the values at the slider scale ?
I get the error every time on all dxf's.
Thanks Chip,
RC
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #258 on: November 14, 2008, 12:04:58 PM »
Hi, RC
Yes, Start z position works + & -, Stock, Profile "Dia.s" only seem to work if you increase the values, Errors if you try to set them below there Initial values.
Chip
Edit: Hears a dxf & tap file, You can adjust to a dia. closer to what you want.
« Last Edit: November 14, 2008, 03:18:48 PM by Chip »
Re: LazyTurn
« Reply #259 on: November 15, 2008, 07:53:23 AM »
Chip,
Are you positing code out of LazyTurn?
