Hello Guest it is November 13, 2026, 07:23:58 AM
Author Topic: LazyTurn  (Read 3675189 times)
0 Members and 8 Guests are viewing this topic.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #790 on: January 16, 2009, 08:17:50 AM »
I seem to be able to load pretty much every dxf I have here..
  Post opne that one load, that used to if you will, Ill see why. I did make some pretty large changes
in the way files are handled in some instances. It may have had an effect.
 As to profile clearance, it shoudl work fine.. Seems OK here.  Tool Params did you use to get that errorbox..
Art
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyTurn
« Reply #791 on: January 16, 2009, 05:12:26 PM »
Hi, Art
Groove tool doesn't work on any files hear. Would you post one of your files that work for you.
Chip
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #792 on: January 17, 2009, 08:35:21 AM »
Sorry Chip, my bad. Had to do with support code for code not yet turned on.
Ill repost in a few minutes with that fixed.
Art
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #793 on: January 17, 2009, 08:39:53 AM »
Heres a version with that support code turned off..
Art
Re: LazyTurn
« Reply #794 on: January 17, 2009, 09:03:04 AM »
Hi Art
This version is A very long time busy greating A toolpath.
After A while the program hangs.
Greetings:
Willem
« Last Edit: January 17, 2009, 09:08:39 AM by W.Jansen »
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #795 on: January 17, 2009, 03:51:10 PM »
Hi, Art, Willem
That fixed it up, All tool's seem to load now, Her's 3 dxf's all the same except for left side shape termination, one good two are bad.
I see you cant rotate the cutter insert's now, In time will get it back when you get the final pass worked out, I'm guessing.
Willem, With the large Units your using, There's allot of calculations going on with small cuts per pass values are used, When proofing the profile try using a larger per pass value, It speeds it up allot.
Thanks, Chip
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #796 on: January 17, 2009, 03:53:13 PM »
funny.. I didnt tell it not to rotate inserts.. they rotate here..
Art
Re: LazyTurn
« Reply #797 on: January 17, 2009, 04:09:42 PM »
Thanks for the update, Art-  :)
Chip, inserts are rotating here as well-
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #798 on: January 17, 2009, 06:07:35 PM »
Hi, Art, Dave
Edit: I figured it out DUaaaaaa, You need to use Lt or Rt Tool select, Not Center..
Thanks, Chip
« Last Edit: January 17, 2009, 07:24:21 PM by Chip »
Re: LazyTurn
« Reply #799 on: January 17, 2009, 07:35:19 PM »
Hi ALL,
Thought you'd have it all sorted out by now.   ;)Guess you need another day or two. :)
