Hello Guest it is October 30, 2026, 11:31:05 AM
Author Topic: LazyTurn  (Read 3620529 times)
0 Members and 4 Guests are viewing this topic.
Offline N4NV
  •  398 398
Re: LazyTurn
« Reply #990 on: April 04, 2009, 07:43:22 PM »
I found the problem.  When I was extracting the program from the compressed file, it was not putting it in the correct directory.  All is well now.  Thanks for the help.
Vince
Re: LazyTurn
« Reply #991 on: April 04, 2009, 09:09:18 PM »
Rich,
 I used:
Pull Clr .05
Stk Clr .01
DPP    .05
IC         .375
T Rad.   .015
I typically keep the flank depth to 1 to 2 times the DPP.
I wouldn't write this part of the manual yet, lol ..it has a ways to go IMO.
Thanks Rich,
RC
Re: LazyTurn
« Reply #992 on: April 04, 2009, 09:35:33 PM »
OK...ONE more post and I swear, I'll sit back and watch as to not be a stumbling block to progress. :)
For whatever reason, this DXF and configuration works PERFECTLY ! But due to the internals, I have no idea why.
35 diamond tool, -22 for RH, +22 for LH turning.
IC            1
TR           .125
Flank CD   .4
Pullout Clr  .05
Stk Clr       .01
DPP          .2
BEAUTIFUL
I guess it IS all in the tools RICH. But this is a weird tool, the other I tried were more standard off the shelf type and sizes.
Just wanted to share some GOOD success,
Russ
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #993 on: April 04, 2009, 11:21:06 PM »
Rich:
  That one where you draw "Actual Tool Radius" the circle shouldnt be any larger than the tool tip, the tool is drawn using actual tool radius..
Your right, the shape is the reuslt of the final pass..
Art
Re: LazyTurn
« Reply #994 on: April 05, 2009, 09:06:24 PM »
ART,
I was able to do this in three rough cuts earlier.  :)
But now, on the second cut it adds the cut to the center line. It seems like it added the volume from the left side cut to the center line.
But with only two cuts and using the 35deg tool the remaining volume is uncut, must be there, and there
should be a volume yete to be removed.
So:  ;)
1 Cut being added on second rough which "creates a volume" that "fools " the calculator into thinking all
   removed, but actualy that is not true.
2.Display can be very misleading.
BTW, i tought you may be able to start at the left end but that didn't work by using the Z pentagon.
« Last Edit: April 05, 2009, 09:10:24 PM by RICH »
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyTurn
« Reply #995 on: April 05, 2009, 09:37:31 PM »
Hi, Rich
Use the 35 deg tool in Center mode first, Then LH & RH tools.
Doesn't seem to bother anyone that the RH tool part's off the work with Rough pass, I Guess.
Thanks, Chip
« Last Edit: April 05, 2009, 09:40:49 PM by Chip »
Re: LazyTurn
« Reply #996 on: April 05, 2009, 09:52:34 PM »
Art,
Maybe this will help in tracking down the problem.  ???
I did two tries at creating paths.
The first changed how the second rough pass was created and notice that the line
to the center is not done and the unexpected which is left. I was then able to do the third rough to clean it up more.
Deleted the first try roughs and tried again.
It did the same thing as in reply #994.
The L and R tools were the same and so were the cuts.
Hope this helps!
Re: LazyTurn
« Reply #997 on: April 05, 2009, 10:01:56 PM »
Hey Chip,
Bothers me a lot!  :(
But as shown above it can work, just need to find the combination to the safe.  ;)
Some how the combination changes.  ??? Kremlin's........where are they?  :-X
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #998 on: April 05, 2009, 10:14:07 PM »
Hi, Rich
I've pretty much tried all those The only one that almost get's it is Center, LH then RH Tool.
It'3 Gremlin's, I know what you mean for sure, Making it Lazy.isn't Easy at All.
Chip
« Last Edit: April 05, 2009, 10:19:30 PM by Chip »
Re: LazyTurn
« Reply #999 on: April 05, 2009, 10:16:59 PM »
Hey Chip,
Just in case you missed an earlier post.
If you hold the following keys down all at once,
APRILFOLSD, you'll get a finsh pass as attached.   :)
