Hello Guest it is October 30, 2026, 11:32:01 AM
Author Topic: LazyTurn  (Read 3620550 times)
0 Members and 4 Guests are viewing this topic.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #1300 on: February 24, 2010, 10:00:15 AM »
Dave:
  Sorry, I missed that till now as I dont use Autocad. Ill make a note to change that in upcoming releases.
Art
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #1301 on: February 24, 2010, 10:24:03 AM »
Hi Guys:
  Well, I guess weve hit that milestone of getting to posting of the finish passes. Obviously we still have some bugs to
deal with , but Im releaseing this anyway because Ill be gone down south for a week, and figured some of you could
at least get a finish pass on those things that DO work..
  Keep reporting.. Ill catch up when I return. This version will also be psted as release 1.0 in the laztcam download, Rich's
excellent manual is included in the release package as well as his example from the docs. Ill compile a list of examples to
add for the next official release.
Be back soon.. :)
Art
Re: LazyTurn
« Reply #1302 on: February 24, 2010, 10:40:26 AM »
Art
Wow Thanks i have been waiting a very long time for turn thanks for getting it this far i will give it a whirl and see how it works.
Dennis
Re: LazyTurn
« Reply #1303 on: February 24, 2010, 10:47:06 AM »
Yahoo! A finish pass last!! Can't wait to try it.
Thanks a million Art!
Kerry Harrison
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #1304 on: February 24, 2010, 10:52:18 AM »
Hi:
 Just be vcery carefull, check your paths carefully before cutting. I did one this moprning and it was fine,
but as we all know, its early to say it works, bugs definitely exist.. that having been said, your finished object
is about to look a whole lot better that before.. The jaggies are gone.. :)
Art
Re: LazyTurn
« Reply #1305 on: February 24, 2010, 11:38:46 AM »
Thanks Art , it still is getting better every new update.
Thanks again:
Willem
Re: LazyTurn
« Reply #1306 on: February 24, 2010, 02:59:17 PM »
ART,
Enjoy the sun. Will check the release out and hopefully finish some sections of the manual while your away.
But most of all just want to do one turning from it, sort of like taking the new car out for it's first ride.  ;)
Re: LazyTurn
« Reply #1307 on: February 24, 2010, 06:00:38 PM »
Guy's i have updated Mach to the latest version and went to install the latest version of LT but now i can't find the green LT icon in the Mach folder to copy LT to why dose this happen aaaaah.
Dennis
Re: LazyTurn
« Reply #1308 on: February 24, 2010, 07:51:41 PM »
ART,
Here is my  first actualy cutting test using LazyTurn. Not bad at all. Didn't realize that no ARC coding was posted until it was done machining. ???
May be wrong, but need arc coding to get a real nice finish or an increased tolerance as that would minimise the straights around the ball.
You can see them in the pics.  Attached pic is  of rough, 1st finish, 2nd  finish, and completed piece.
I decided to do a quick new Appendix "A" and rough draft is attached.
« Last Edit: February 24, 2010, 07:57:05 PM by RICH »
Re: LazyTurn
« Reply #1309 on: February 24, 2010, 08:04:33 PM »
Dennis,
Where did you put it?
