Hello Guest it is October 24, 2026, 04:54:47 PM
Author Topic: LazyTurn  (Read 3546640 times)
Re: LazyTurn
« Reply #490 on: December 16, 2008, 07:44:10 PM »
CHIP,
I certainly second what your saying as the windows save is still not right and it would be nice to have it.
I did some 50 dxf postings and it is certainly adds up to wasted time. But the saving as just posted will be a good assist also. Maybe ART will comment.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #491 on: December 16, 2008, 10:44:59 PM »
sorry guys, I kept missing that problem, Ill have it fixed next release.
Art
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyTurn
« Reply #492 on: December 16, 2008, 11:34:59 PM »
Hi, Art, Thanks, Chip
Re: LazyTurn
« Reply #493 on: December 17, 2008, 03:52:52 AM »
Thanks so much, Art, that would be teriffic -
Re: LazyTurn
« Reply #494 on: December 17, 2008, 10:36:25 AM »
Art,
Thanks for fixin the slider, I wondered how I was going to get to 0.0....
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #495 on: December 17, 2008, 09:40:20 PM »
Hi Guys:
  File fix.. This one will create or overwrite files..
Art
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #496 on: December 17, 2008, 10:03:03 PM »
Hi, Art
Work's Great, Thank You.!!'
Chip
Re: LazyTurn
« Reply #497 on: December 17, 2008, 10:12:03 PM »
Nice fix....thanks.
Here is another strangeness.
The profile OD is 2.8146
If the Stock OD is set at any value less than 2.85, the small OD's of the profile will not be cut.
Easy enough to just "lie" about the actual stock OD to get around this but it seems like entering any value OVER the Profile OD should generate the desired paths.
Thanks again,
RC
Re: LazyTurn
« Reply #498 on: December 17, 2008, 10:24:19 PM »
I think I see why.
The Depth Per Pass is added to the Profile OD which becomes the min. Stock OD.
Maybe that's the way it is supposed to be.
RC
« Last Edit: December 17, 2008, 10:25:59 PM by Overloaded »
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #499 on: December 18, 2008, 07:26:40 AM »
Hi Guys:
   True. Its the original stock dimension assumtion thats killing that one. Perhaps I should add a small amount to the stock ( say 5%) as a rule
as the piece loads. The user can then set the dimension, but due to the way the algorithm works, it does need soem stock overage to properly
identify the first pass. Ill add that to my list.
  We're almost ready to move to the next stage I think, things are working pretty well overall, so Im looking to see what my plan is for the next progression,
I havent decoided yet what is most logical, but we'll see what happens.
Thx
Art
