Hello Guest it is October 24, 2026, 04:04:54 PM
Author Topic: LazyTurn  (Read 3546213 times)
0 Members and 13 Guests are viewing this topic.
Re: LazyTurn
« Reply #930 on: March 27, 2009, 06:34:30 PM »
Dave,
 In your example, the angle of the tool may well prevent the finish pass from cutting the end or face. But in the example I used, the tool was angled -22 deg. I should have included that in the post.
Russ
Re: LazyTurn
« Reply #931 on: March 27, 2009, 06:39:26 PM »
The tool can actually be seen i the earlier post. Difficult though in wire frame.
Re: LazyTurn
« Reply #932 on: March 27, 2009, 08:07:39 PM »
Ah, I get it now, thank you-
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyTurn
« Reply #933 on: March 27, 2009, 10:21:23 PM »
Hi, Russ
I think it's, Rough & Finish/Rough and I'm sure I missed part of the Point's as usual.
Edit: In your dxf, It's missing the RH,  Final/Rough pass, I think.
Just little Diff/Bug's or whatever.  ;D
Chip
« Last Edit: March 27, 2009, 10:31:41 PM by Chip »
Re: LazyTurn
« Reply #934 on: March 27, 2009, 10:56:41 PM »
Chip,
 Both pics in #930 are the same part showing the Rough and the Finish paths separately to show where the Finish profile does not cut the finish pass at the end or face of the part. Looks good on your King though...may be a radius thing ..... strange.
RC
Re: LazyTurn
« Reply #935 on: March 27, 2009, 11:21:28 PM »
Here is another strangeness.
2 tools, one RH(-22 deg.) and second LH(+22deg.). Actually the same tool and CUT settings, just angled the insert and reversed direction.
1st cut does as expected but the second cut cleans out the corner AND cuts the entire profile removing the selected stock clearance.
I would expect it to only clean out the corner.
RC
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #936 on: March 27, 2009, 11:40:27 PM »
Hi, Russ
The example of your Quick-disconnect I used was modified by me and  I tried several way's/end-point's.
Chip
Re: LazyTurn
« Reply #937 on: March 28, 2009, 01:18:38 AM »
Art,
A few minor comments,
1.View menu and status bar -The zoom out and zoom in are reversed in View tool box and also the
                                  associated prompts you get in the status bar.
2.Options menu - if the start Z is a positive value, a scale is not provided in the graphics area post importing a file.
3.When using the keyboard - ALT key will not highlight / underline the Options, Debug, and  Toolpaths
                                         - ALT is also use for changing the crosshair to windows default pointer ( no
                                           problem but just wanted to mention this )
4.LazyTurn Project flyout - if you  close it, How do you bring it back without going out of and back into Lazyturn?
5.Do you have a listing of which Ctrl, Alt, and other keys combinations are intended to be functional in LazyTurn?
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #938 on: March 28, 2009, 03:10:34 AM »
Hi, Art
Hears a Test AA.dxf that brings out some issues, I know it's early on in your cleanup of the new routines. So take a look at if you get a chance.
This is about the same as figuring out the final move's on a Rubik's Cube's last Layer, Thanks for giving us a Pre-view of things to follow.
Edit: replaced the AA file it had an error at Z0.0 start of .0089.
Chip
« Last Edit: March 30, 2009, 12:40:48 PM by Chip »
Re: LazyTurn
« Reply #939 on: March 29, 2009, 03:25:15 AM »
strange?
