Hello Guest it is October 23, 2026, 01:11:29 PM
Author Topic: LazyTurn  (Read 3541033 times)
0 Members and 5 Guests are viewing this topic.
Re: LazyTurn
« Reply #1120 on: August 24, 2009, 10:21:19 PM »
Tere is a Lazyturn May28 in post 1067 this is the one i used at first and it did not give the full menu's As i said when i installed the one you mentioned chip it worked fine.
Re: LazyTurn
« Reply #1121 on: August 24, 2009, 10:38:43 PM »
Funny, as I am using the May 28 version and no problem. Don't know what to say.  ???
I quess a file download can be like Spam ,which is basicaly a case of bad meat in the can! ;)
I don't like Spam.
Re: LazyTurn
« Reply #1122 on: August 24, 2009, 10:49:48 PM »
Rich
We are only in trial anyway, what does your version do that the may 25 version does not do? This does not produce code yet or does it? i have tried but i think i need to read more in the manual.
Re: LazyTurn
« Reply #1123 on: August 25, 2009, 05:56:19 AM »
Bigbigjimbo,
It just optimises the rough passes .
 LT will post code to a file but not directly into Mach3 turn. For a single finish pass  you can use LazyCam . There is a manual in Member's  Doc's for LC. See Tutorial #5 for a how to ( it uses the same file as used for the LT Manual ). Note that you need to look at the whole manual as each tutorial builds on each other.
Re: LazyTurn
« Reply #1124 on: August 28, 2009, 08:56:08 AM »
I am using LazyTurn to generate the roughing profiles for my turning, and LazyCam to generate the finish pass.  LT works fine on XP, but I need to use it on Vista and I have the following problem:
When I try to generate g-code in LT, using a new file name, LT says it can't find the file, and gives me an notepad file, which is empty.  I have LT 1.1.  If i start with a existing .tap file, I get the old file, unchanged.
I took LT to another Vista machine, same result.  Tried on an XP machine, and everything works fine.
Any thoughts would be appreciated.
Thanks, Barry
Re: LazyTurn
« Reply #1125 on: August 28, 2009, 09:27:09 AM »
I assume you have LC pro as that will post code, as far as Vista ( i use XP ) don't know what to tell you since i have never used it.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #1126 on: August 28, 2009, 09:28:57 AM »
Hi:
  It has to do with Vista not allowing you to modify a file in certain folders. Try right clicking and selecting "Run as Admin", OR failing that, save the file to your desktop..
Art
Re: LazyTurn
« Reply #1127 on: August 28, 2009, 09:31:33 AM »
Art,
SO what's up with LazyTurn? In the Fall?
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #1128 on: August 28, 2009, 09:55:42 AM »
Hi Rich:
  My plan is for first snows... :)
 Im working on a summer project approaching working status ( A next-generation planner) , so once I finish this I'll be back at LT, or on first snow II'll switch back. I needed the break to get fresh again.
Art
Re: LazyTurn
« Reply #1129 on: August 28, 2009, 10:13:40 AM »
ART or Brian,
I am curiuos, will you or Brian ever / someday do any changes to LazyCam.
There is manual for it in the Members Docs and at the end of it there is a bug list.
Of that list, there are only a few important ones that require fixing.
