Hello
Guest
it is
October 24, 2026, 04:05:50 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
LazyTurn
LazyTurn
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
Go Down
Author
Topic: LazyTurn (Read 3546223 times)
0 Members and 11 Guests are viewing this topic.
budman68
2,352
Re: LazyTurn
Reply #340 on:
December 01, 2008, 04:00:06 AM »
I believe I had this same problem and I switched to Diameter mode and it fixed it.
Give that a try but I'm sure Rich will be here soon to tell you -
Logged
Dave->
sanlee
33
Re: LazyTurn
Reply #341 on:
December 01, 2008, 04:59:58 AM »
Thanks Dave for the guidance i have tried it by changing mode from radius to dia from the Config/ports & pins/turn option. but the result is still same
no improvement is found. Any more suggessions?
sanlee
Logged
Re: LazyTurn
Reply #342 on:
December 01, 2008, 05:56:21 AM »
Sanlee,
Check or uncheck "Reversed Arc's in Front Post" located in CONFIG>PORT&PINS>TURN OPTIONS
Logged
sanlee
33
Re: LazyTurn
Reply #343 on:
December 01, 2008, 06:05:37 AM »
Thanks RICH
I did check and uncheck both in "Reversed Arc's in Front Post" located in CONFIG>PORT&PINS>TURN OPTIONS. but still result is not getting. where should i wrong i dont know. please any further suggessions?
sanlee
Logged
Re: LazyTurn
Reply #344 on:
December 01, 2008, 06:09:50 AM »
Got to go, back later today rich
Logged
Re: LazyTurn
Reply #345 on:
December 01, 2008, 07:36:58 AM »
sanlee,
just tried the file, you need to be in diameter mode and reversed arc's unchecked
Logged
budman68
2,352
Re: LazyTurn
Reply #346 on:
December 01, 2008, 12:27:05 PM »
Ok, so I was part right........lol!
Logged
Dave->
Chip
2,055
Gainesville Florida USA
Re: LazyTurn
Reply #347 on:
December 01, 2008, 02:18:45 PM »
Hi, All
It's a Chess King, This is correct mode, Hear anyway, Radius mode and Reversed arc's unchecked.
I appears after Mach3R3.041 there are Display Issues in Mach3
Chip
Logged
Re: LazyTurn
Reply #348 on:
December 01, 2008, 07:23:52 PM »
Chip,
Just upgraded to MACH 3.042.020 and also see the issues with the display, so your not alone.
In fact for some reason it won't zoom out as far as it did before which is very annoying. Can't even see
a small part any ideas?
Last Edit: December 01, 2008, 07:36:17 PM by RICH
Logged
sanlee
33
Re: LazyTurn
Reply #349 on:
December 01, 2008, 11:25:36 PM »
RICH,
sorry to say you that i have tried the file in diameter mode and reversed arc's unchecked but still there is no improvement in result. Also i have updated Mach3 R3.04 and opened the same file but still result is same as shown in below photo. i dont know what is wrong with my side.
sanlee
Logged
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
Go Up
« previous
next »
