Hello Guest it is October 31, 2026, 12:58:41 PM
Author Topic: LazyTurn  (Read 3632523 times)
0 Members and 6 Guests are viewing this topic.
Re: LazyTurn
« Reply #1520 on: September 23, 2011, 11:04:28 PM »
I knew Art made Lazy Turn lazy on purpose but it should be rested up by now.  ;)
Sure would be nice if it could wake up this winter and get those bugs on the To Do list fixed. I use it regularly and it's a pain to have to edit the same errors out of the code each and every time.
Just a gentle nudge to let you know we're using the lazy bugger out here.  :)
Kerry Harrison
Re: LazyTurn
« Reply #1521 on: January 26, 2012, 01:56:12 PM »
Hay guys,
Can someone point me towards a tutorial for Lazycam and maybe which version would be best to use?  Thanks in advance!
Chris
Re: LazyTurn
« Reply #1522 on: January 26, 2012, 03:39:40 PM »
Chris,
There is a manual for LazyCam and Lazyturn in Members Docs .
Kerry,
You never know what Art may decide to do. Don't want to build up your hopes though.
If there were more folks using it he would probably do something with it but unfortunately that dosen't seem to be the case.
Re: LazyTurn
« Reply #1523 on: January 26, 2012, 03:57:47 PM »
That makes sense Rich. I figured it doesn't hurt to ask though.
Kerry
Re: LazyTurn
« Reply #1524 on: January 28, 2012, 08:26:12 PM »
If the manuals were more visible, maybe more people would take the plunge knowing the resources were out there. It's not until I set up Mach Turn to run a recently retrofitted Sherline that I found there was a LazyTurn manual. There are a lot of messages asking if manuals even exist.
Re: LazyTurn
« Reply #1525 on: January 29, 2012, 03:26:10 AM »
Open to any suggestions since here is what is listed under Documentation.
Re: LazyTurn
« Reply #1526 on: October 07, 2012, 09:04:56 PM »
Hay guys
"There is a manual for LazyCam and Lazyturn in Members Docs "
cent find it  link whold help
tenks
Re: LazyTurn
« Reply #1527 on: October 08, 2012, 05:36:47 AM »
TENKS,
Click on Members Doc's and about the 2nd and tenth threads you will find the manuals.
Re: LazyTurn
« Reply #1528 on: October 08, 2012, 05:25:44 PM »
hi rich
i cant find the " Members Doc's " area serch 7 cent findit
where is it the folder i ment
thanks
asi
Re: LazyTurn
« Reply #1529 on: October 08, 2012, 06:06:23 PM »
asi,
under MACHSUPPORT FORUM
-Scroll down to Support, click on  Members Doc's
-13 th down the list of postings....click LAZYTURN MANUAL
Open or download the manual.
or
http://www.machsupport.com/forum/index.php/topic,10091.msg62041.html#msg62041
