Hello Guest it is October 23, 2026, 01:11:13 PM
Author Topic: LazyTurn  (Read 3541029 times)
0 Members and 5 Guests are viewing this topic.
Re: LazyTurn
« Reply #940 on: March 29, 2009, 04:55:55 AM »
Hi Zeeschuim
Send your DXF , maybe there is something wrong with it.
Greetings:
Willem
Re: LazyTurn
« Reply #941 on: March 29, 2009, 06:01:53 AM »
hoi Willem
Hoe is het?
Hereby the dxf.
Re: LazyTurn
« Reply #942 on: March 29, 2009, 07:21:10 AM »
Hi zeeschuim,
When showing the "strange" things, possibly give your tool info and procedure as that would help us to know what's causing the strange occurances or at least it gives Art some food for thought  ;)
Thanks!
Re: LazyTurn
« Reply #943 on: March 29, 2009, 08:28:57 AM »
Hi zeeschuim,
I did see at least one thing that may be upsetting the toolpath in your dxf.
Please see the screenshot below at the end of the ball.
While I'm not a pro, this does not look like it would set up right in Lturn.
Re: LazyTurn
« Reply #944 on: March 29, 2009, 08:54:47 AM »
Yep, thats it,
Re: LazyTurn
« Reply #945 on: March 29, 2009, 09:39:17 AM »
Hi Zeeschuim
Those guys are way ahead of me.
Before I could react the problem is already solfed.
Greetings:
Willem
Re: LazyTurn
« Reply #946 on: March 31, 2009, 02:00:17 PM »
Hi All,
I am attaching a rather simplle dxf file which is being used for a section
in the manual. Each and every input, setting, etc in Lazyturn is being tested against it.
I would say it's a beginners file but provides for easy checking of gouging, application of
different tools etc.
If you guys could include it as one of you standard test files and see if anything goes
wrong would appreciate it.
Also attached is a few sections of the manual.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyTurn
« Reply #947 on: April 01, 2009, 12:06:30 AM »
Hi Art
I want to post some issue's I'm finding, But have never really asked you what format you'd prefer, MM, INCH, RAD, DIA, Modes ?
Just looking for what will Help the Most and cause less confusion & conversion.
Thanks, Chip
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #948 on: April 01, 2009, 01:17:43 AM »
Hi, Art
Hears a couple small one's, Could you turn Off the auto split view after every "Cut" that's generated ?
When you change the Stock Diameter value the  Blue marker changes, But the value box freezes and doesn't reset till you click on Start Z or Set Z Offset marker and an "OK" fixes it.
Chip
« Last Edit: April 01, 2009, 01:23:49 AM by Chip »
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #949 on: April 01, 2009, 08:12:46 AM »
Chip:
 Thx, Ill fix up the arrow functions. I have no real preference for rad/dia/mm/inch , all of them in the end need to work so any pointers of errors are fine
in any mode. A new version is close to being ready and Ive changed a bit of the functions, and have made the simulation variable speed forward and backwards
so one can see how the tool will move around.
  Ill kill the autosplit and make it work simply on the button now that I dont need the removal anymore in diagnostics.
Thx
Art
