Hello Guest it is October 23, 2026, 01:11:18 PM
Author Topic: LazyTurn  (Read 3541031 times)
0 Members and 5 Guests are viewing this topic.
Re: LazyTurn
« Reply #390 on: December 06, 2008, 06:41:56 PM »
ART,
-I get a memory error after closing LazyTurn which I never got before.
-Don't know if the small rough cut error is significant, but lazyturn didn't do it on the other faces of this profile.
 What caught my attention was when i found the start and end point of the line happen to end in xx9.
 Couldn't duplicate with other values of stock and depth values. Maybe just a fluke.
Your making it harder to find stuff.
Re: LazyTurn
« Reply #391 on: December 06, 2008, 06:43:39 PM »
The dxf for reply #390
Rich
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyTurn
« Reply #392 on: December 06, 2008, 08:41:37 PM »
Hi, Rich, Art
I'm having the same Issues, It's gotten So bad that None of the files I've used before  seem to work.
Well I think It's something in the LaxyTurn .XML is getting Corrupted, So I re-named the XML, That way it has to start up Fresh and now It works Again For Now.
Even the BobCad v23 file I wanted you to look at.
Edit: Found Problem XML, Below
Will See, Chip
« Last Edit: December 06, 2008, 10:03:27 PM by Chip »
Re: LazyTurn
« Reply #393 on: December 06, 2008, 10:47:45 PM »
Chip,
Assume your like me hacking away, bouncing between programs, numerous Layturn tries....I just had to reboot the PC after a while and it seemed like Lazyturn went back to normal. I am going back through all of my dxf files and checking one by to see if i can find anything.
Now if you get bored with the normal, try getting the attached to work, guaranteed to give error....it's a face turned on it's side.
Man was it hard trying to trace my egg! ;D
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #394 on: December 07, 2008, 01:03:06 AM »
Hi, Art
The XML file in Reply # 392 two posts above has an error in it, It appears to be the RoughClearance value ," 1.", When I change it to "0.1"  LazyTurn start's working Again.
I have No idea how it got set to that value, As I've never changed a LazyTurn .xml before.
Thanks, Chip
« Last Edit: December 07, 2008, 01:15:21 AM by Chip »
Re: LazyTurn
« Reply #395 on: December 07, 2008, 08:16:25 AM »
Morning,
I got a chance to do some of were I left off. Chip, I cannot duplicate the .jpg you have in mess#387. I did not rework the file I have yet,and am going to attempt,to do something different. What I got now ,is the following screen shot's... Take a look!.. Hope This Worked.:O
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #396 on: December 07, 2008, 10:30:22 AM »
Hi, Hank
There is a dxf of your part on page 39 last post #389, It's cleaned up, Give it a try.
Chip
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #397 on: December 07, 2008, 11:03:34 AM »
Hi, Rich
Hear is a Profile, You really can't cut it completely, But it's there, LazyCam generated not LazyTurn.  ;D
Chip
Re: LazyTurn
« Reply #398 on: December 07, 2008, 11:53:04 AM »
Hi All
I made a profile but when i create a toolpath the distance between toolpath and profile is not everywhere the same (profile5).
If i set the inscribed circle at zero the toolpath looks good (profile6).
Greetings:
Willem
« Last Edit: December 07, 2008, 12:14:17 PM by W.Jansen »
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #399 on: December 07, 2008, 12:15:07 PM »
Hi, Willem
I think part of the problem is you really need to draw your profile as below.
Profile should be drawn in X - , Y + quadrant of your cad, Starting/Placing  profile from 0.0  right to left.
Your part Diameter will not be correct if the top of your profile issen't set in ref. to Y zero line.
This may change when things are finalized and rough and finish is combined, Don't now for sure.
Hope this Helps, Let me Know.
Thanks, Chip
« Last Edit: December 07, 2008, 02:36:20 PM by Chip »
