Hello Guest it is October 23, 2026, 01:11:19 PM
Author Topic: LazyTurn  (Read 3541031 times)
0 Members and 5 Guests are viewing this topic.
Re: LazyTurn
« Reply #1320 on: February 27, 2010, 12:05:55 PM »
Post the dxf and the tap file.
Re: LazyTurn
« Reply #1321 on: February 27, 2010, 01:21:01 PM »
Here ya go...
Kerry
Re: LazyTurn
« Reply #1322 on: February 27, 2010, 02:48:13 PM »
What your seeing in Mach3 Turn is true based on your posted tap file and there is big gap
differance between the rough and finish.
Now i can make the rough and finish passes that work, based on your dxf and you don't get what you show.
Can you post a pic of your rough and finish pass settings along with the tool info?
Re: LazyTurn
« Reply #1323 on: February 27, 2010, 03:19:28 PM »
Requested files...
Kerry
Re: LazyTurn
« Reply #1324 on: February 27, 2010, 04:56:12 PM »
Kerry,
  You have LT in DIA. mode but I think the finish only comes out in RAD mode.
Switch to RAD mode and see what you get.
This is your file in Rad mode.
Russ
Re: LazyTurn
« Reply #1325 on: February 27, 2010, 06:07:59 PM »
kerry,
In what program and what version of that program did you create the dxf?
By any chance was it exported out from a 3d file?
Re: LazyTurn
« Reply #1326 on: February 27, 2010, 06:29:55 PM »
Switching to RAD mode in LT seems to have made it work. I've attached a screenshot from Turn showing the results. Will Turn have to be switched to radius mode to run these files correctly?
The DXF file was created in the AutoCAD 2009 in 2-D mode not 3-D. I saved the file as AutoCAD 2007.
Kerry
Re: LazyTurn
« Reply #1327 on: February 27, 2010, 09:04:02 PM »
Hi All,
An updated version of the LazyTurn Manual /  rev 6 inclusive of appendix ABC&D can found in the members docs.
Re: LazyTurn
« Reply #1328 on: February 27, 2010, 09:12:47 PM »
Kerry,
You will find that in the manual i just posted i have said you should draw, export, import, and have Mach3 Turn set  for the same mode.
I had trouble duplicating what you and Russ did since it wouldn't change no matter what mode i put mach turn in.
I take it you saved it as a version 2007 dxf.
A few other programs identified it as  3d dwg, 2000 would not import it.......
I am thinking that 2009 puts some crap into the dxf and causes problems .......don't know for sure....just a guess
Re: LazyTurn
« Reply #1329 on: February 27, 2010, 10:52:18 PM »
Please pardon my ignorance Rich but where is the members docs?
Kerry
