Hello Guest it is October 23, 2026, 03:12:31 PM
Author Topic: LazyTurn  (Read 3541258 times)
0 Members and 16 Guests are viewing this topic.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyTurn
« Reply #560 on: December 25, 2008, 10:04:55 PM »
Hi, Art & All
Latest 25-4 seems to work hear also, U-Ho-Ho-Ho-Ho, Thanks Art.
Back to Testing, Now where was I testing ?
Thanks, Chip  :D
« Last Edit: December 25, 2008, 10:32:07 PM by Chip »
Re: LazyTurn
« Reply #561 on: December 26, 2008, 04:06:01 AM »
Hi Art
With this toolsettings a get a tooltip failure at the moment when the toolpath is almost made.
Greetings:
Willem
Re: LazyTurn
« Reply #562 on: December 26, 2008, 05:41:25 AM »
Willem
Just curious, if you increase the inscribed circle to .101, .11 will it generate the toolpaths.
Post the dxf file ( or ref the post# where it was posted), this allows others to do a run the same file and provides for comparison. I have found that the slower pc's here can take a long time to generate a toolpath or maybe bomb on
the file.
Re: LazyTurn
« Reply #563 on: December 26, 2008, 05:47:47 AM »
Hi Willem,
  Also looks like your Z is incrementing in the wrong direction. Wrong quadrant possibly ?
And, are you using the latest release ?  I ask because your pointers are not colored as the latest release fixed this on mine.
Like Rich said, your dxf would help.
RC
Re: LazyTurn
« Reply #564 on: December 26, 2008, 06:48:15 AM »
Rich
If i increase to 0.15 it will generate a toolpath (very nice) but see that the button change in a triangle??????
If i make the tool smaller (0.01) it also make a nice toolpath but take a long time to create
My pc is a dualcore 1.9ghz 1gb memory laptop so that should be sufficient.
RC
Not exactly sure what you mean with the word quadrant but Chip already did explain that i have to draw on the - side of the origin so i get the Z in the - direction.
When i use the file Chip make for me (see second file) i get the same result
I used the latest release but the previous release did the same.
Greetings:
Willem
Re: LazyTurn
« Reply #565 on: December 26, 2008, 06:57:27 AM »
Hi RC
A little addition.
As soon as i select a tool the colors of the pointers disappear.
Greetings:
Willem
Re: LazyTurn
« Reply #566 on: December 26, 2008, 07:19:55 AM »
Willem,
Chips explanation is what I meant about the quadrant.
I spoke too soon about the colors. I only keep the colors after tool selection if the accel. is at notch 2 or lower.
Re: LazyTurn
« Reply #567 on: December 26, 2008, 07:34:14 AM »
WJ
Never saw a tool like that before.
If your depth per pass is really small, it will take quite a while to generate the paths.
RC
Re: LazyTurn
« Reply #568 on: December 26, 2008, 07:40:26 AM »
Willem is not alone.
Latest version. There are still tool graphics issues.
RC,
Nothing has fixed pointer color issue here. See attached. But I have to take a hard look at what services i have turned
off . Maybe it all depends on how you want look at it! ;)
« Last Edit: December 26, 2008, 07:43:35 AM by RICH »
Re: LazyTurn
« Reply #569 on: December 26, 2008, 07:40:58 AM »
Hi RC
The last tool (0.01) is fiction (only for testing) on mi age i would not even see the tool (lol).
Greetings:
Willem
