Hello Guest it is October 24, 2026, 04:06:37 PM
Author Topic: LazyTurn  (Read 3546233 times)
0 Members and 11 Guests are viewing this topic.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #1480 on: December 18, 2010, 08:15:10 PM »
Hank:
 The meaning of the error is:
ERROR 0XC0000022: STATUS_ACCESS_DENIED.This error is due to {Access Denied} A process has requested access to an object but has not been granted those access rights..The default facility code
  Try running in Admin mode.. Win7 can be a pain when not runnign a program in admin mode.  Just select properties for the shortcut and turn on admin mode for the program.
  Other sites say there is a file in the system folder that is mistakenly set to read-only when you upgrade Win7.. you may want to search a bit for that if admin doesnt fix you up.
Art
Re: LazyTurn
« Reply #1481 on: December 19, 2010, 07:36:04 AM »
Art,
Got it, and will put this one on the shelf, for Another day. I know $$IT will happen Again,and I might be Prepaired...
Thanks,   Hank S.
Re: LazyTurn
« Reply #1482 on: January 10, 2011, 03:49:36 PM »
Rich,
Very nice Read in DM. I, and others should gain some more knowledge,and be more adpt, to LT. Very Interesting,and should be added to my folder on books that really mean something. Ah, but there are always the Grimlins, that need a stir as usual. Thanks for Your Input, Great Job.    Thanks,   Hank S.
Re: LazyTurn
« Reply #1483 on: January 10, 2011, 04:05:29 PM »
Thanks Hank,
Hopefully there will more LT users having fun with their lathes because of the article.
Re: LazyTurn
« Reply #1484 on: January 16, 2011, 10:35:03 AM »
Thanks Hank,
What article? Getting ready to start the conversion of a manual lathe to CNC and am starting to look for lathe CAM options. A friend mentioned Lazy Turn so am reading up on it, where its at in development, what it can and can't do. Home shop environment, having lots of fun learing. Easy CAM options a definite plus!
Thank Art for your effort on this...
Marty
Mesa, AZ
Re: LazyTurn
« Reply #1485 on: January 16, 2011, 10:37:00 AM »
That would be the article in Digital Machinist that I believe just came out.
Re: LazyTurn
« Reply #1486 on: January 16, 2011, 11:55:52 AM »
MARTY,
Here is the link to a manual for LT in Members Docs. It covers what it can and can't do.
http://www.machsupport.com/forum/index.php/topic,12078.msg77415.html#msg77415
An article about LT was published in the Winter 2010 Digital Magazine. The manual covers the program in depth.
Re: LazyTurn
« Reply #1487 on: January 18, 2011, 11:15:52 PM »
Greetings,
Any idea why LT is creating finish passes inside the finished part?
Please have a look at the attached files.
Thanks much,
Kerry Harrison
Re: LazyTurn
« Reply #1488 on: January 19, 2011, 06:18:05 AM »
MARTY,
Rich I find the docs for LAZY CAM but not LT??
Re: LazyTurn
« Reply #1489 on: January 19, 2011, 06:39:15 AM »
Hi Kerry,
  The radius point for the tip of your drawing is actuall in the Y+ quadrant creating an undercut at the face end of the profile.
I changed the radius point to be Y 0.0000 and it seems to be OK .
You could try my modified DXF to verify.
Just a shot, hope it helps.
Russ
