Hello Guest it is November 13, 2026, 07:23:52 AM
Author Topic: LazyTurn  (Read 3675188 times)
0 Members and 8 Guests are viewing this topic.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #310 on: November 27, 2008, 09:44:39 AM »
Hi Guys:
  Weird the way the mice are telling the system theyve been clicked..  Ill tighten up the code and remove that, in the meantime, he's a stock fix..
Art
Offline bowber
  •  216 216
  • Kirkby Stephen,Cumbria, UK
Re: LazyTurn
« Reply #311 on: November 27, 2008, 09:57:54 AM »
Hi
Hitting the N key does the trick, I really am going to have to read all the previous posts to get clued up on all this stuff.
Steve
Re: LazyTurn
« Reply #312 on: November 27, 2008, 10:04:36 AM »
And don't be afraid to experiment, Steve, and post your findings as this is what this is all about -  :D
Offline bowber
  •  216 216
Re: LazyTurn
« Reply #313 on: November 27, 2008, 10:36:58 AM »
Well I've had a mess around with a simple part, basicly a ball on the end of a stick.
This is all just in lazyturn, no actual cutting.
I used a button cutter to make one set of code and the roughing was very rough, big steps etc.
I then tried a groove tool (basicly a parting blade) and the roughing was much smoother, same settings as the button cutter, 0.1mm pull out and stock clearance with 0.5mm per pass.
I would have thought it would be the other way round ???
Anyway it's looking good, certainly lazy so far.
Steve
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #314 on: November 27, 2008, 10:41:14 AM »
Steve:
  It is counter to intuition. A button tool woudl grouge the stock more easily due to the radius of the tool. A triangle or groove woudlnt, it can get
closer to the profile without hurting it. Remember, all we generate at this point is the roughing path. Fine paths will be awhile yet..
Anyway, play with it and post what you find. No promised shcedule, its my "fun" project so its a slow one.
Art
Offline bowber
  •  216 216
Re: LazyTurn
« Reply #315 on: November 27, 2008, 10:58:24 AM »
No problem Art, it'll be a while before I have a CNC lathe ready as well, just getting up to speed with it all.
I do have some profiling to do that I was going to use my mill as a lathe for but other considerations mean that I'm going to use a profile tool in my manual lathe.
steve
Re: LazyTurn
« Reply #316 on: November 27, 2008, 11:23:44 AM »
Art, if I may ask, what PC hardware and OS are you running? Just curious is all-
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #317 on: November 27, 2008, 12:12:51 PM »
Hi Dave:
  I have faster computers, but I develop on a asus 2.3Ghz unit, with 1Terabyte of harddrive space and 2 24" monitors. Nothing too special..
Art
Re: LazyTurn
« Reply #318 on: November 27, 2008, 12:37:40 PM »
Ok, thanks, just curious to know since some of the things ran differently for us.
I realize systems can be alike and yet so different as far as video drivers and the rest so it got my curiousity going.  :)
Re: LazyTurn
« Reply #319 on: November 27, 2008, 01:09:17 PM »
Hi ART,
  Thanks for the STOCK fix.
The PART dia. pointer is also off.......over the dwg. dia.
Take your time.....good work.
RC
