Hello Guest it is October 24, 2026, 10:03:29 PM
Author Topic: LazyTurn  (Read 3549792 times)
Re: LazyTurn
« Reply #1240 on: February 12, 2010, 01:00:30 PM »
ART,
Would it be possible to put a restraint, prior to generating code, such that the generated Gcode would stop somewhere along the Z?  I am thinking,  as a posting option one could say ie; the piece is 4" long but only create code for the first 2" of the profile.  So that posting option would allow one simple breakup of profile.
Re: LazyTurn
« Reply #1241 on: February 12, 2010, 01:35:47 PM »
That would be a super handy option.
Very worthwile imo.
Thanks for suggesting it Rich.
RC
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #1242 on: February 12, 2010, 01:55:57 PM »
Rich:
  Yup, already considering that one.
Art
Re: LazyTurn
« Reply #1243 on: February 12, 2010, 08:19:57 PM »
Anybody else seeing differences in the roughing... from Dec 14 to Feb 8 ?
Same settings/tools.
Re: LazyTurn
« Reply #1244 on: February 12, 2010, 08:36:58 PM »
...actually, the roughing on this particular profile went awry here with Jan 26_2010.
Cannot make the Dec release fail.
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #1245 on: February 12, 2010, 10:41:59 PM »
Hi:
Can you post that dxf.. Ill give it a shot
Art
Re: LazyTurn
« Reply #1246 on: February 12, 2010, 10:46:25 PM »
Russ,
See if it is gouging. May also want to post the dxf and also try a Visual Intersect Diags
on it.  ???
MODIFIED: THE DXF IS NOT RUSS'S BUT IS CLOSE TO IT IN SIZE
« Last Edit: February 12, 2010, 10:49:14 PM by RICH »
Re: LazyTurn
« Reply #1247 on: February 12, 2010, 11:02:41 PM »
Russ,
Zoom way in at the point and then use the TEST TOOL LOCATION in Debug and place the tool on the
upper pass. Zoom WAY out again. I my case, i can see the gouge in the lower section and then in the upper one
it is not gouging or say .0001" on rough measurement.
Note that scan line diagnostics are done with the gouging "off".
I would have thought that the path after the gouge would have started earlier.
« Last Edit: February 12, 2010, 11:17:53 PM by RICH »
Re: LazyTurn
« Reply #1248 on: February 13, 2010, 07:39:50 AM »
Hey .. thanks for looking at it.
 Here is the dxf and the tool.
Russ
Re: LazyTurn
« Reply #1249 on: February 13, 2010, 07:44:16 AM »
These two pics.
Exactly the same duplicate setups.
Feb8_2010
Normal attempt, and scan line diagnostics.
