Hello Guest it is October 30, 2026, 01:03:45 PM
Author Topic: LazyTurn  (Read 3621224 times)
0 Members and 17 Guests are viewing this topic.
Re: LazyTurn
« Reply #840 on: February 07, 2009, 01:28:12 PM »
This one is done with a different tool and the latest version.
See comments.
What can i say, back in training!  ;)
Re: LazyTurn
« Reply #841 on: February 07, 2009, 01:38:21 PM »
Need to do go  :( ,  back in a few hours.
Re: LazyTurn
« Reply #842 on: February 09, 2009, 02:45:32 PM »
Hi Art,
If I'm understanding correctly, this is an example that you can use for fault finding?  It looks good up to pass 3, but fails as shown on pass 4.  the file is one that was posted here a while back.
Cheers,
Paul
Re: LazyTurn
« Reply #843 on: February 10, 2009, 11:35:20 AM »
Hi Art
Saw you posted a new version i have not downloaded this version but in trying the last version on a profile the cut profile didn't work the profile has an 8 MM radi at one end the G-code and graphic in Mach turn did not show or perform any radi moves however it did show the radi in LT so i don't know what i did wrong maybe you can shed some lite on whats happening attached arre the files.
Dennis
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #844 on: February 10, 2009, 11:43:35 AM »
Sorry, I deleted that version, here is a new one.
 Ill look at the tunnel file and see what I can see.
Art
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #845 on: February 10, 2009, 11:45:06 AM »
Hi:
 Try latest version, new_tunnel fiel seems to work here fine..
Art
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #846 on: February 10, 2009, 11:47:12 AM »
sorry,I missed the point on the tunnel file..
 Lturn never generates a radii, it wtill only does roughing, and roughing is always just straight line cuts..
Art
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #847 on: February 10, 2009, 11:58:04 AM »
OK, I promise, no more versions today after this one..
Fixes some zooming issues on smaller items..
Art
Re: LazyTurn
« Reply #848 on: February 10, 2009, 12:57:04 PM »
Art
LT won't do any radi OK that settles that will it do radi in the future version or never at all i thought in the finish pass it would do radi.
Dennis
Re: LazyTurn
« Reply #849 on: February 10, 2009, 01:00:01 PM »
Art
looked at LT on the screen it shows the cut lines around the radius so i don't understand if it only dose straight lines then why would it show the cut line as a radius?
Dennis
