Hello Guest it is October 23, 2026, 02:05:58 PM
Author Topic: LazyTurn  (Read 3541103 times)
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #650 on: December 31, 2008, 08:13:43 AM »
>>However how long are we looking before you guys release a commercial version with a finishing toolpath included.
  It coudl be awhile. ( A LONG while.).
  I do intend to do a finish profile next, so at that point, if you take great care, you could cut jobs. It may not be too long before it at least outstrips lazycams ability, it already does in some respects. But as a hobby project I set no timelines, I suspect it will be buildiong over time for a long time, but I do wish to get it cutting profiles at least in the near term. The intermediate step between rough and finish is actually the key to completion, its a very hard step to do, but will add quite a bit of capability in terms of keeping it easy and lazy, which is a primary concern for me.
Art
Re: LazyTurn
« Reply #651 on: December 31, 2008, 07:16:23 PM »
Here's a few of some things gone bad,I tried to post before,and it did'nt work,so here is another shot at it Thanks   Hank S.
Re: LazyTurn
« Reply #652 on: December 31, 2008, 07:34:17 PM »
Hi Hank,
  That does look a bit weird.
I'll bet there is something awry in the DXF.
Can you post the DXF ?
RC
Re: LazyTurn
« Reply #653 on: December 31, 2008, 07:36:59 PM »
Happy New Year!
Here is what I tried to post before. Pullout 0.050,Stock Clear0.050,and depth of cut0.010. It cuts off the round edges of the part,Don't know if this is my problem or? Have to offset a vertical line in the dwg. for it will not produce,and says line intersept. I tried all I can do to get this to work for me,unless there is something I am missing,Which is usually the case.  Thanks,    Hank S.
Re: LazyTurn
« Reply #654 on: December 31, 2008, 07:42:05 PM »
Hank,
Happy new year ti you too !
You probably have intersecting/overlapping lines or entities in your DXF, can you post it?
Might be able to see where they are and point them out to you.
RC
Re: LazyTurn
« Reply #655 on: December 31, 2008, 07:44:40 PM »
RC
I tried to, and the web keeps saying i double posted already, Something strange going on here. Give it acouple of minutes ...  Thanks,   Hank S.
Re: LazyTurn
« Reply #656 on: December 31, 2008, 07:46:40 PM »
Give it a new name and start a new reply.
Can be a PITA !
RC
Re: LazyTurn
« Reply #657 on: December 31, 2008, 07:49:14 PM »
Hey!
Ok, lets see if this works...  Thanks,  Hank S.
Re: LazyTurn
« Reply #658 on: December 31, 2008, 07:52:06 PM »
OK...There are definetly some probiems with it.
You need to send the actual DXF file from your CAD...not a JPG picture or capture.
The DXF will have all of the dwg. info so we can open it up and look at it.
RC
Re: LazyTurn
« Reply #659 on: December 31, 2008, 07:56:49 PM »
Again?
What am I suposed to look,or do,for what? I'm not a PC guy,just an old manual  machinist going cnc. Explain what I should be looking for.  Thanks,  Hank S.
