Hello Guest it is October 30, 2026, 01:04:10 PM
Author Topic: LazyTurn  (Read 3621232 times)
0 Members and 16 Guests are viewing this topic.
Re: LazyTurn
« Reply #550 on: December 25, 2008, 10:32:04 AM »
ART,
Getting a 406 error now.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyTurn
« Reply #551 on: December 25, 2008, 11:42:31 AM »
Hi, Art
Some files are loading now, But just in outline only, No graphics or tool showing and thy will post code.
Other files generate a 406 error, All though one did show full graphics, But 406 error trying to generate Rough view.
Thanks, Chip
Re: LazyTurn
« Reply #552 on: December 25, 2008, 11:48:08 AM »
Hi Guys,
  I did some experimenting trying to correct the pointer color display. I found this.
With the acceleration at FULL, there is no 406 error. However, if it is lowered to the setting shown, I get the 406.
I always keep mine FULL so I wasn't getting the errors.
RC
Re: LazyTurn
« Reply #553 on: December 25, 2008, 12:24:14 PM »
Hi Art
Did try the settings from RC and get the same results, no error on full acceleration and a 406 error on lower setting.
Greetings:
Willem
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #554 on: December 25, 2008, 12:48:12 PM »
Hi, RC
Doesn't seem to help hear, My BobCad v23 won't tolerate a setting above 2 clicks from None on the Acceleration.
Thanks, Chip
Re: LazyTurn
« Reply #555 on: December 25, 2008, 01:02:39 PM »
Hi Chip,
   When I use SheetCam, I need to set it at 2 clicks above NONE like you, but leave it up otherwise. I didn't suggest it as a fix but as a possible indication or clue for ART.
   Try this DXF on HIGH.. see what you get. ACad, Autodesk, Autosketch generated.
RC
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #556 on: December 25, 2008, 01:32:52 PM »
Hi, RC
Your dxf works on ver prior to 12 23 08, But I get a 406 error on latest version no mater what the Accl. values are set to.
Thanks, Chip
Re: LazyTurn
« Reply #557 on: December 25, 2008, 03:33:19 PM »
HI All,
Well added another pc#4 for testing, NEC LAPTOP 400MHZ / 256 RAM.
Only good to prior 12 23 08 versions and will give the ( 214 error for dec 24 ver ),
(TODO for dec 24-3 ver) , ( 406 error for dec 25 ver),
but it dosn't loose the color in the x trangles.
Changing accel values didn't do any good. All the computers here are set to the highest accel.
Lets see, four different computers here of varying make and model all running XP. The slower ones with less than
500 mhz / 512 only get to prior versions of DEC 23. The fastest / most memory only has a problem wiith loss of color
in the pointer / unless you flip it 180 degrees ( along with oss of color in the associated dimension boxes) but can run the DEC 25 VER with no problems other than stated.
RC, no problem with your posted file in #555.
 ??? Beats me as if it's a Windows setting somewhere.  ???
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #558 on: December 25, 2008, 05:57:05 PM »
Hi Guys:
  Interesting.. seems it may have been a simple "-" sign I added for "safety". LOL
Try this one..
Art
Re: LazyTurn
« Reply #559 on: December 25, 2008, 07:03:06 PM »
ART
Good going, works for all three computers. Now let me see if i can break it.  ;)
