Hello Guest it is October 25, 2026, 01:54:59 AM
Author Topic: LazyTurn  (Read 3552208 times)
0 Members and 10 Guests are viewing this topic.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #420 on: December 08, 2008, 03:09:24 PM »
Hi Hank:
 New version remebers depth of cut.
Art
Re: LazyTurn
« Reply #421 on: December 08, 2008, 03:09:44 PM »
ART,
In Dec8, "Depth per Pass" is persistant but it moves the decimal point 2 places to the right.
Enter .025 and it reopens as 2.5  consistant with any entry.
RC
Re: LazyTurn
« Reply #422 on: December 08, 2008, 03:32:47 PM »
Also, could you please explain what this LEAK represents ?
It is present after closing LT but only when a path has been generated.
It seems to increment up 1 for each path generated while a given profile is open.
RC
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #423 on: December 08, 2008, 03:55:14 PM »
Hi:
 Sorry about that, I had tested it, but I may have been in just radius or diamter mode..
The Leak isnt actual, its a warning that the object wasnt deleted by LTurn as it closed, I need to search for it, very small
objects so its not a big deal really.
Seems intermittant.. But Ill search for it..
Art
Re: LazyTurn
« Reply #424 on: December 08, 2008, 04:02:28 PM »
Thanks ART.
Further investigation reveals that if the DEPTH is set at only 1 decimal place, .2 for instance, it sticks. But if you enter .025 or .02  it jumps to 2.5 or 2 respectively.
RC
« Last Edit: December 08, 2008, 04:04:02 PM by Overloaded »
Re: LazyTurn
« Reply #425 on: December 08, 2008, 05:07:29 PM »
Art,
Maybe a clue for you.
 The Rough Pullout screen, when first opened in previous versions, showed the tool depth setting for the tool you selected, and noticed that the depth setting is off by "THREE" decimal places. Just did this for the botton tool and havn't checked the other tools.
In fact it seems to vary.
created        rough depth
tool depth
.002             2
.032             3.2
Rich
Re: LazyTurn
« Reply #426 on: December 08, 2008, 05:50:11 PM »
Art,
For most tests i have been using the button or diamond.
I get TO DO's with the square tool.
Should we avoid any tool's? Can post the file with info?
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #427 on: December 08, 2008, 10:23:55 PM »
hmm, Ill run some test swith square tools.. Post the file just in case..
Art
Re: LazyTurn
« Reply #428 on: December 08, 2008, 10:58:54 PM »
Hi Guys,
No TODO error but this path looks bad at the flange of this spindle with the selected square tool.
RC
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyTurn
« Reply #429 on: December 08, 2008, 11:25:35 PM »
Hi, Art
LazyTurn is getting better all the Time For Sure, For what it worth.
If you set Read Only to the LT.xml with a value of 0.1 for RoughPass.
When you start LT the value changes to .2 then it's a divide / multiply issue that persists.
If  Depth Per Pass is 0.10 PerPass =.0500 turns into 10 Depth Per Pass next time Rough Profile is opened again.
If  Depth Per Pass is 0.15 PerPass =.00750 turns into 15 Depth Per Pass next time Rough Profile is opened again.
and so-on. Pic's
Thanks, Chip
« Last Edit: December 09, 2008, 12:01:54 AM by Chip »
