Hello Guest it is October 30, 2026, 01:02:59 PM
Author Topic: LazyTurn  (Read 3621209 times)
0 Members and 16 Guests are viewing this topic.
Re: LazyTurn
« Reply #230 on: November 11, 2008, 06:39:45 AM »
RICH,
  Tool tip straight up is 0 deg. Left is neg. deg., right is pos. deg.
RC
Re: LazyTurn
« Reply #231 on: November 11, 2008, 08:39:09 AM »
I get an error just trying to install LTurn, any suggestions?
Re: LazyTurn
« Reply #232 on: November 11, 2008, 08:43:12 AM »
jhowelb,
Put lazyturn.exe in the folder with mach or wherever you installed lazycam.
Re: LazyTurn
« Reply #233 on: November 11, 2008, 08:51:00 AM »
Figured it out, the update is not an installer but is the new file to be placed in the Mach folder.
Re: LazyTurn
« Reply #234 on: November 11, 2008, 08:55:52 AM »
RICH,
I like your suggestion about the Button tool with NO restraints on the tool holder.
I have applications where that would be extremely handy.
Especially when finish pass and face cutting come into being.
RC
EDIT: And re-reading your earlier angle question, I see that my response was not what you needed.
But...it may be of help to others for reference to the orientation of the other inserts.
« Last Edit: November 11, 2008, 09:47:06 AM by Overloaded »
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #235 on: November 11, 2008, 10:25:06 AM »
Rich:
  True enough, I can see where you could designa holder to cut that one for example..but it isnbt right, I see the lobes are cutting off..
Im still working on the why's of that one. Ive found some further errors, but they are complex to repair so it'll be a few days while I take that into account.
Art
Offline tantan
  •  130 130
Re: LazyTurn
« Reply #236 on: November 11, 2008, 01:42:11 PM »
hi, everything works fine on my computer (vista) except generating G-Code. when i import the Aouterprofile.dxf file, select tool and generate toolpath all is OK. when I generate G-Code lazyturn asks for the prolog and filename. after that notepad opens but without G-Code?
thanks
antoine
the netherlands
Re: LazyTurn
« Reply #237 on: November 11, 2008, 03:53:17 PM »
Ok, had a little time to play today and did a few tests with some profiles but I'm not sure how much help I'll be.
I used this profile from Rich the first time with success :
I had these results in the pics below. Pay no attention to the missing cut lines as I paused through it part way and it really did seem to "cut" everything well. I'm also including my Diamond tool profile so that you can see exactly what I used.
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #238 on: November 11, 2008, 03:57:57 PM »
Hi Guys:
 hmm, seems some of you have openGL issues of some kind.. Im still searching..
As to Vista, yes, it does fail to save the file, its another hting Im tracking down.
Art
Re: LazyTurn
« Reply #239 on: November 11, 2008, 04:30:00 PM »
Hi Art, if it helps, I'm using an Nvidia Geforce 6800 video card.
