Hello Guest it is October 30, 2026, 01:01:41 PM
Author Topic: LazyTurn  (Read 3621184 times)
0 Members and 17 Guests are viewing this topic.
Re: LazyTurn
« Reply #1230 on: February 10, 2010, 01:14:28 PM »
 ART,
Glad they helped. It also gives a new user an approach to using LT and may shorten the learning curve.
As far as the manual, I would envision it would lag by about a month, but, there would be a
 concurrent revision very soon after the release. I will probably just lump a whole bunch of comments
 into an appendix callled verbage holding.This would save comments that may apply at a future time.
A new thread may be in order once it's released since the manual along with appendix will cover all
 of the replies in this thread.
Till the next update,
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #1231 on: February 12, 2010, 11:12:49 AM »
Hi Guys:
  Thought youd like to see latest output showing proposed finish pass only, with no roughing..
Art
Re: LazyTurn
« Reply #1232 on: February 12, 2010, 11:18:32 AM »
Sure did !
Looks GOOD !
Re: LazyTurn
« Reply #1233 on: February 12, 2010, 11:25:06 AM »
HMM....
So the cuts of the finish pass will follow the profile contour and not like some other programs where they do small
X / Z moves with just a final profile cut.
Correct?  way to go!
Re: LazyTurn
« Reply #1234 on: February 12, 2010, 11:27:35 AM »
I'm stoked,
I may have to give up sleep this weekend to finish the lathe just to try it out.
It just gets better and better.
Way to go Art.
Re: LazyTurn
« Reply #1235 on: February 12, 2010, 11:44:30 AM »
And yet another work of "Art"  ;D
Sorry, I realize that one's been beaten to death but I bet Art never gets tired of hearing/reading it.
Thanks, Art, it looks fantastic-
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #1236 on: February 12, 2010, 12:27:58 PM »
Rich:
 Yes, the final pass will always be the full countour, but the pre-rouging of the finish pass will be the lines I show in the example, but culled to lines only that actually take material out of the
remaining stock from other roughing and finish passes which may have been done. SO the only time youd get passes as above, is if you hadnt roughed or finished with another tool.
Art
Im just gratefull its still pretty lazy to use, Im trying to keep user selections to a minimum.
Re: LazyTurn
« Reply #1237 on: February 12, 2010, 12:38:23 PM »
Hi Art,
To make it any lazier, you would have to make it load the machine for you.
Just my 2 cents but for most of us it looks like it is already done. The undercuts and other assorted crazy stuff are for the future, not so lazy cam.LOL
Mike
Re: LazyTurn
« Reply #1238 on: February 12, 2010, 12:42:54 PM »
ART,
So you will leave the finish as shown in the example such that a rough or finish pass is not "mandatory".
Will LT post code for those lines?.....or is it just a visual when no rough & finish were done.
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #1239 on: February 12, 2010, 12:53:15 PM »
Rich:
  Ive decided that how or if you rough is up to you. If you dont rough, youll get exactly ( pretty much ) as you see in the picture. BUT , if you were to do another
finish with another tool, you may get only the one finish pass, or mayeb two or three outward, depending on how muach material remains fromt he first finish
operations.
  So the general rule for any rough or finish is it will post code only for motions that remove material.
Art
