Hello Guest it is October 24, 2026, 10:08:18 PM
Author Topic: LazyTurn  (Read 3549835 times)
Re: LazyTurn
« Reply #360 on: December 03, 2008, 12:59:30 PM »
AOK ART.....I gotcha now.
RC
Re: LazyTurn
« Reply #361 on: December 03, 2008, 02:18:26 PM »
NICE, Art!
Dave  :)
« Last Edit: December 03, 2008, 02:24:20 PM by budman68 »
Re: LazyTurn
« Reply #362 on: December 03, 2008, 08:13:07 PM »
Art,
I'll include the files when if I find something. The insanity in my naming convention goes something like this.
A_B dxf_hcir_*********xx
A=REFERENCE TO MY FOLDER
B=DRAWING NUMBER
hcir= rich
*********x= C MEANS COMMENT 1,2,3, ETC FOR THE POSTING, OR DESCRIPTION IE; GCODE
RC,
Yep, looking forward to the show in York. Are you going?
Re: LazyTurn
« Reply #363 on: December 04, 2008, 01:51:31 AM »
Thankyou HOOD, CHIP, RICH and other friends
My problem is solved by changing the mode i.e IJ  :). This is good learning with you all.
Thanks again
sanlee
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyTurn
« Reply #364 on: December 04, 2008, 02:24:38 PM »
Hi, Art
It appears that having a horizontal line on C/L 0,0 start causes a Open GL Error's, But it allows the Rough Cut to start at 0,0 C/L.
If it's has a vertical line or has no line at the 0,0 start the Rough Cut starts Short of the  0,0 C/L.
Any Thoughts, Chip
« Last Edit: December 04, 2008, 02:30:00 PM by Chip »
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #365 on: December 04, 2008, 02:36:54 PM »
Chip:
  Yes, its illegal to have a c/l line. TO control the start position of the cut, use the main options menu, you can set a Z-Offset from the piece there.
Ill add code to remove any c/l object found. That shoudl clear that up. :)
Art
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #366 on: December 04, 2008, 02:37:20 PM »
Hi, Art, All
Hears the dxf's and a Post of the top picture hear, Rough and Finish.
 Edit: Thanks, Art i'll give it a try, But will this fix the Rough not starting at 0,0 C/L ?.
Thanks, Chip
« Last Edit: December 04, 2008, 02:48:12 PM by Chip »
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #367 on: December 04, 2008, 03:01:17 PM »
Hi, Art
I had the Z-Offset set to .1, Set it to .25, Only change was more Z setback, Rough still falls Short of 0.0 C/L.
Edit: "In the cut, use the main options menu, you can set a Z-Offset from the piece there.", Do we need a X Rough Offset from 0,0 C/LValue Also. ?
Thanks, Chip
« Last Edit: December 04, 2008, 04:17:01 PM by Chip »
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #368 on: December 04, 2008, 04:17:08 PM »
Chip:
 Ahh, sorry, I misunderstood. Now I see the issue. Ill look into the algorithm and see if I can force it to zero. It automatically decides when to stop based on some pretty strange criteria due to some profiles that may cut inward ( like a cup shape ), since a tool woudl snap cutting inwards, it stops early.. But in your case it looks like it shoudl continue inwards..
Art
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #369 on: December 04, 2008, 05:21:25 PM »
Hi, Art
Thanks, It's sometimes hard to give an explanation that's clear with these finger's.
Just want to say, Things are working very well.
If you can get " Ill add code to remove any c/l object found", this should fix most of the other OpenGL issues, I'm thinking.
Cutting a Ball End and or a Part Cutoff should be a vertical line or Cir/Arc move.
I had noticed if a Horizontal line was off the Z Zero point it didn't cause the OpenGL error.
As I've asked before, Have you thought of a way to do Inside Cut's.
At this time using LazyTurn and LazyCam Turn to do Rough and Finish Post's is pretty Easy.
Thanks for all you do Art.
Chip
