Hello Guest it is October 23, 2026, 05:14:52 PM
Author Topic: LazyTurn  (Read 3541650 times)
0 Members and 23 Guests are viewing this topic.
Re: LazyTurn
« Reply #170 on: August 02, 2008, 09:45:19 PM »
Offline Perfo
  •  143 143
Re: LazyTurn
« Reply #171 on: August 02, 2008, 09:55:23 PM »
Some nice pieces there thanks. Not having done many DXF to Gcode conversions (read this as none)  how would you know by downloading a DXF if your 3 axis mill will be able to make it once Mach 3 has got hold of the DXF and converted it? The Knight looks a little tricky with 3 axis.
« Last Edit: August 02, 2008, 09:57:34 PM by Perfo »
Re: LazyTurn
« Reply #172 on: August 03, 2008, 02:34:13 AM »
The knight would have to be 4 axis, either that or do one side and then flip and do the other.
Offline Perfo
  •  143 143
Re: LazyTurn
« Reply #173 on: August 03, 2008, 06:06:57 PM »
Do you use lazyturn on a mill as well or only on Lathes ? I can see me wanting to put another axis on once I get going to do this kind of thing. Learn to walk before running I must constantly remind myself of that :)
Re: LazyTurn
« Reply #174 on: August 03, 2008, 06:55:54 PM »
Lazy turn is for turning and Lazycam is for millig, plasma, router, waterjet, ect.
Brett.
Re: LazyTurn
« Reply #175 on: August 04, 2008, 04:47:44 AM »
But if you add a 4th axis to the mill and use it as a spindle, mount a lathe tool in a clamp in the Z Axis and use it as an X axis and use the X axis as a Z axis then you would use MachTurn and LazyTurn :D
Offline Perfo
  •  143 143
Re: LazyTurn
« Reply #176 on: August 04, 2008, 07:47:04 PM »
Nice. If you can understand it :)
Re: LazyTurn
« Reply #177 on: August 05, 2008, 12:46:22 PM »
Re: LazyTurn
« Reply #178 on: August 05, 2008, 01:00:20 PM »
one picture = 1000 words!
http://www.youtube.com/watch?v=wbfXXeiSHsw
Not exactly what I was meaning but yes that is another way to do it :)
Re: LazyTurn
« Reply #179 on: August 05, 2008, 01:03:38 PM »
This was more like what I was meaning except instead of mounting the lathe on the mill it would just be your 4th axis.
http://tormach.com/Product_PCNC_lathe.html
