Hello Guest it is October 25, 2026, 05:55:09 AM
Author Topic: LazyTurn  (Read 3554870 times)
0 Members and 12 Guests are viewing this topic.
Re: LazyTurn
« Reply #10 on: February 13, 2008, 02:25:46 PM »
Hmm, I'll try & get the Z to change and let you know how I did it :)
Let the user (god bless them ;)) define his stock sizes. but otherwise that's exactly what I was thinking
steve
Re: LazyTurn
« Reply #11 on: February 13, 2008, 02:59:12 PM »
Art,
I'm anxious to try this but I get what you see below.
I have LCam and the Lic.
Do I need to download the latest version ?
I have the version with the mysterious "Assist" button. V2.61
RC
« Last Edit: February 13, 2008, 03:01:16 PM by Overloaded »
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyTurn
« Reply #12 on: February 13, 2008, 03:24:17 PM »
Hi:
 Update your lcam to latest version. It uses that dll as well.
Art
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyTurn
« Reply #13 on: February 13, 2008, 03:36:39 PM »
Hi, Art
Looks pretty nice, Seem's to load profiles easer.
When you get to the tool stuff.
I'd like to see an option that just cut's the profile whether it's inside or outside, That let's the User determine the cutter
shape/profile needed to clear the profile.
At this time with LC, It's pretty confusing and hard to get a complete profile to generate.
Thanks Art for All You Do, Chip
Re: LazyTurn
« Reply #14 on: February 13, 2008, 03:51:15 PM »
OK,
the Z..
The numbers stay the same it just shrinks if you put a bigger stock size in & vice versa, I suppose thats natural ::)
those origin arrow don't show up very well in green against a blue background :-\
I've just imported a dxf but it didn't import it the size it was drawn, is there something I'm missing?, I changed it ok but it's not very lazy (ok I know it's early days yet :)) oh length was ok
Here's another one - when stock is same size as job the pentagon goes brown.
A box showing max dia & length would be handy ;) while I'm on  a roll... how about a origin splot you know the white circle with 2 oposite quarters in black.
bonne chance
psst the help file's a bit thin  ;D
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #15 on: February 13, 2008, 09:48:55 PM »
HEres an updated program that is more suitable I think. The toolpaths will be generated on the bottom to emulate the lathe from the top. The arrows show the positions
of the stock, profile and bore, they are clickable. The MRU works, and the hovers have a contrast bhox behind them and work much better..
  Stock diamter will appear as highligted rings, click to select, or click on the stock arrow to set it manually. All settings are now autofocus as well so
you can enter easily a change..
 Good ideas..thx..
Art
Offline ART
  •  1,703 1,703
Re: LazyTurn
« Reply #16 on: February 13, 2008, 09:50:39 PM »
oh, and the pic..
Re: LazyTurn
« Reply #17 on: February 13, 2008, 10:22:30 PM »
ART...COOL
The hover box is too small for 4 dec. metric #'s..
The contrast could be better as mentioned earlier..
Keep it up,
RC
« Last Edit: February 13, 2008, 11:14:47 PM by Overloaded »
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #18 on: February 13, 2008, 11:18:22 PM »
Hi, Rc
Look at your dxf, It needs to be a single line segment I think.
Post one of them.
Chip
Offline Chip
  •  2,055 2,055
Re: LazyTurn
« Reply #19 on: February 13, 2008, 11:31:39 PM »
Hi, Art
Numbers not finding the little white windows and 0.0's out of place, unit's based on inch in DXF.
Thanks, Chip
