Hello Guest it is November 11, 2026, 11:43:03 AM
Author Topic: Mach4 Printer Port Discussions  (Read 2214876 times)
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #780 on: June 11, 2015, 10:20:03 AM »
Hi Sebastion:
   Im not sure why that would happen. In your system registry, does Darwin show up as
properly licensed? Even that shouldnt cause this symptom, but Im curious if theres a relationship.
I cant think of anything that would stop Darwin and M4 talking.. Is this the latest version of each?
Art
« Reply #781 on: June 11, 2015, 11:28:28 AM »
Hi Art,
the latest Version of both components are installed.
You write I can get the license info from the System registry- where can I find the entry?
(Really a registry key?)
« Reply #782 on: June 11, 2015, 11:36:10 AM »
Okay- new info:
I found it (help - System Information -plugins)
You're right: Plugins -> mcDarwin Shows "Not licensed"
The licence key is her: C:\Mach4Hobby\Licenses. Whats wrong?
Do I have to execute anything in darwin for licensing like in Mach4?
Offline ART
  •  1,703 1,703
« Reply #783 on: June 11, 2015, 12:07:14 PM »
Hi:
   You need to download a new license, the keys went bad at one point. A new key should fix it.. if not, Mach4 itslef
needs to be updated..
Art
« Reply #784 on: June 11, 2015, 12:29:48 PM »
Okay, I reinstalled Darwin and the license file-
now I see that the license is valid.
All issue seems to be fixed now-
thank you for your tipps!
Great work, glad to use the software!
Best regards,
Sebastian
« Reply #785 on: June 11, 2015, 12:39:43 PM »
Sebastian,
FYI, the latest version of Darwin that I've seen is 2461-a and was uploaded by Art in post 762, May 20, 2015.  The one shown on the Mach download page is very old.
Peter
« Reply #786 on: June 11, 2015, 02:18:30 PM »
Yup, and just so you will know, I try to keep the very first topic of this post updated to include links to the latest plugin.
http://www.machsupport.com/forum/index.php/topic,27194.msg191918.html#msg191918
« Reply #787 on: June 11, 2015, 03:18:17 PM »
Did not know that.  I just go to the latest posts.  Given there are a huge number here, I don't start at the beginning.   ;)
It might be helpful if the latest were to be posted under the latest M4 download.  Or maybe that's NOT the latest download.   ;D
Peter
Offline dude1
  •  1,253 1,253
« Reply #788 on: June 11, 2015, 04:23:06 PM »
that's because there is no licence
they give X amount of time for testing only if you wont it to run all the time you have to get a licence
« Reply #789 on: June 13, 2015, 05:18:19 PM »
Hello Art
Any luck on resolving my step/direction spindle frequency issue?
Eric.
