Hello Guest it is October 24, 2026, 10:23:55 PM
Author Topic: Mach4 Printer Port Discussions  (Read 2148551 times)
0 Members and 8 Guests are viewing this topic.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #750 on: May 18, 2015, 04:40:52 PM »
Hi Sasha:
 Im told it means your darwin license is wrong. Your license file inside should say NF_DARWIN in the file you got.
Can you confirm its there? Did you load it using the help/about in m4? In the file you got it should be similar to
# License created: 01-10-2014
# MAC: D00B-39DE3C35656130D2
# Expires on DD-MM-YYYY: 26-04-2044
# Licensed application:
#    Name: "NF_DARWIN"
#    Description: "Darwin Plugin License"
# Features included:
#         M4_DARWIN
# Custom data:
#         url=http://www.machsupport.com
#         support=support@machsupport.com
   Is the M4_DARWIN in yours? You may have copied the wrong file..
Art
« Reply #751 on: May 19, 2015, 03:09:41 AM »
Hey Art,
yes i loaded the file via help--> About--> Load license file.
My file in the folder mach4hobby/licenses looks like this:
# License created: 17-05-2015
# MAC: 080B-0019996A7E89
# Expires on DD-MM-YYYY: 10-12-2044
#    Name: "NF_DARWIN"
#         M4_DARWIN
# Custom data:
# === Start copy after the BEGIN LICENSE line and ===
# ===      finish before END LICENSE line         ===
----- BEGIN LICENSE -----
I downloaded the file again from my account. with the same problem.
Sascha
« Last Edit: May 19, 2015, 03:16:50 AM by sascha_039 »
Offline ART
  •  1,703 1,703
« Reply #752 on: May 19, 2015, 06:40:16 AM »
Do you still get error -35?
Ive reported this to the programmers.. but Im not sure why its happening to you.
Art
« Reply #753 on: May 19, 2015, 06:47:04 AM »
Yes i get it.
Thats very sad because my machine has to run. I can't produce at the moment.
Offline ART
  •  1,703 1,703
« Reply #754 on: May 19, 2015, 07:05:31 AM »
Sasha:
   I just tested mine and it runs fine. Does your Mach4 show its licensed properly? Im thinking your ID may be wrong.
I cant see anything on Darwins side that coudl do that. I suggest you check your Mach4 licnse and make sure its reporting good,
and if it is, contact M4 support, because it should be running and it should never give a -35 unless the license is bad.
Art
Offline ART
  •  1,703 1,703
« Reply #755 on: May 19, 2015, 08:15:34 AM »
Hi Sasha:
 Ive reported this and their testing, I think all win7 licenses for Darwin have stopped working.
Should be fixed soon..
Art
« Reply #756 on: May 19, 2015, 08:58:11 AM »
Hey Art..
ok, then i have to wait, hopefully they fix it very soon.
Sascha
Offline ART
  •  1,703 1,703
« Reply #757 on: May 19, 2015, 09:13:16 AM »
Sasha,
Their checking it now.
Art
Offline ART
  •  1,703 1,703
« Reply #758 on: May 19, 2015, 09:31:09 AM »
Hi Sahsa
  Bug is confirmed , seems to be in Win7 only, a fix is in the queue, hopefully youll hear soon.
Art
Offline ART
  •  1,703 1,703
« Reply #759 on: May 19, 2015, 12:43:49 PM »
Sasha:
 Bug is fixed. Should be out very shortly. If not, email me personally and Ill send you a copy of the installer.
Thx
Art
