Hello Guest it is October 24, 2026, 08:25:50 PM
Author Topic: Mach4 Printer Port Discussions  (Read 2147742 times)
0 Members and 6 Guests are viewing this topic.
Offline dude1
  •  1,253 1,253
« Reply #690 on: January 27, 2015, 09:56:27 PM »
there bet you to it again art 2192 out
« Reply #691 on: January 28, 2015, 05:52:20 AM »
Art
Is there a back door that i can make my changes in besides going through Mach4 ?
Thanks for your time
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #692 on: January 28, 2015, 07:33:31 AM »
Tom:
   The only way I can think off is to set it up on another machine and then copy the profile.ini to your machine..
Sounds liek a rough way to go..
Art
Offline ART
  •  1,703 1,703
« Reply #693 on: January 28, 2015, 07:33:59 AM »
Try 2192 and see what It does...
Art
« Reply #694 on: January 28, 2015, 09:40:10 AM »
Will try 2192 this evening
Thanks again for your time
« Reply #695 on: February 06, 2015, 08:28:54 PM »
Art,
I installed M4 V1.2192 and it played nicely with Darwin V1.2178.  When I installed M4 V1.2214, things broke.  I couldn't jog and homing only worked on the Z axis, sort of.  I reinstalled M4 V2.2192 but no joy.  I uninstalled everything and reinstalled M4 V2.2192 and Darwin V1.2178 but things are still broken.  Then I noticed that Darwin shows version numbers 1.21 over 1.19, not 1.21. over 1.23.
How do I force Darwin to update?  Is there a version for M4 V1.2214?
Peter
Offline ART
  •  1,703 1,703
« Reply #696 on: February 06, 2015, 08:45:59 PM »
Peter:
  theres a 2209 , but it hadnt been put out yet..
Heres a copy of the ifles..
Art
« Reply #697 on: February 06, 2015, 10:06:59 PM »
Thanks Art.
I uninstalled everything then installed M4 V1.2192 and Darwin V2209 ('manual' install).  Now I get a Darwin -33 license failure.  Do I need a new license?  M4 seems okay.  I did put the Darwin license in the license folder for M4.
When I installed Darwin 2209, it said the versions were still 1.21 over 1.19.  Do I need to go into the system drivers and remove Darwin there before reinstalling?
Pete
Offline ART
  •  1,703 1,703
« Reply #698 on: February 07, 2015, 07:19:55 AM »
Hi Pete:
  Yes, remove the system driver, its the 1.19 and should be 1.23.
 Delete any copies of Darwin.sys that reside on your computer ( do a dearch for that file.).
Then reinstall...
Art
« Reply #699 on: February 07, 2015, 09:46:51 AM »
Art,
Thanks.  As you can probably surmise from my last post yesterday, deleting the driver was a last minute idea as I was posting.  I verified that it fixed the version problem.  The license issue went away after I used the right license file.  Sheesh.
Everything is back to normal (except me).
Thanks.
