Hello Guest it is November 13, 2026, 05:57:36 AM
Author Topic: Mach 4 Bug Reports  (Read 882776 times)
0 Members and 6 Guests are viewing this topic.
Re: Mach 4 Bug Reports
« Reply #310 on: March 13, 2015, 11:31:58 AM »
Not sure if this is a bug or if it's just something in my script..... if I have my machine disabled and hit a keyboard jog key and then I enable the machine it will start moving the axis even though the jog key is not being pressed anymore.
« Reply #311 on: March 14, 2015, 02:34:35 PM »
LED on Mach screen hide when 'hidden' is set to 1, but do not display when 'hidden' is set back to zero
« Reply #312 on: March 17, 2015, 01:35:52 PM »
When in the screen edit mode, if I try to type an incorrect format type into the format property of a DRO such as "1f%" and hit enter, it causes the program to crash and close and I lose all of my work. very frustrating when I am a little lisdexic sometimes.
« Reply #313 on: March 17, 2015, 04:09:59 PM »
When you cut and paste a static text field from one page to another in the screen edit mode, the text field looses its BOLD style setting.
« Reply #314 on: March 18, 2015, 08:15:16 AM »
Update: This problem seems to occur only when the controls are in a panel.
Offline Bronk
  •  12 12
Re: Mach 4 Bug Reports -- Homing issues
« Reply #315 on: April 05, 2015, 06:53:31 PM »
I am using mach4 with ESS
The machine will home but:
1. Homing speed is extremely slow. It does not matter what speed percentage I set in the config homing config screen, it alwasy is just a crawl. I have not measured theactual speed but it is << 0.1 inches / sec and rapids are currently set for 300 IPS.
What would be desirable would be a routing to go rather quickly to home (if not already at home), back off then crawl in for accurate stop
2. The home offset does not seem to work.  My Z axis trips the home switch when it is all the way up (roughly +6.5" compared to the table top). I cant get the home offset to set a value, it is always 0 when homed.
I have saved these values and restarted multiple times but no luck.
Offline dude1
  •  1,253 1,253
« Reply #316 on: April 05, 2015, 07:51:12 PM »
you will need a script to do it in M4
« Reply #317 on: April 05, 2015, 08:07:54 PM »
In the ESS config you can set the to and return speeds for homing.
Later plugins are rumored to respect the home off distance.
« Reply #318 on: April 06, 2015, 05:01:27 AM »
Is there a fully functional plugin yet? The website still has the initial Beta plugin, several months old, which doesn't include many features.
« Reply #319 on: April 06, 2015, 07:05:17 AM »
I got a test plugin from Greg a few weeks ago that was a breeze to setup and seems rock solid with the very limited testing I did. But, it was a test plugin. I know Greg is planning to post a new plugin soon. What features will be or not be implemented is something Greg would have to answer.
