Hello Guest it is November 13, 2026, 05:57:32 AM
Author Topic: Mach 4 Bug Reports  (Read 882776 times)
0 Members and 6 Guests are viewing this topic.
Re: Mach 4 Bug Reports
« Reply #60 on: May 10, 2014, 10:36:01 AM »
HIYA GUYS,G60 doe not seem to work correctly. The #param does not work and the toolpath seems a bit strange for a G60 as I remember it.
The toolpaths are not consistant with the Gcode intent.  The toolpaths should still follow the Gcode intent from point to point THEN correct for Backlash and proceed.
Just a thought, (;-) TP
« Reply #61 on: May 10, 2014, 10:36:58 AM »
Terry that makes perfect sense for the up down button script choices.
but, why not just make it a momentary action option button
« Last Edit: May 10, 2014, 10:42:47 AM by Ya-Nvr-No »
« Reply #62 on: May 10, 2014, 02:08:26 PM »
Because then you have to define momentary, 1sec 10sec 100sec ? this way You define momentary by holding down on the button as long as required.
« Reply #63 on: May 10, 2014, 02:19:13 PM »
No what I ment was that the button was only active while in the down position.
so button state is always 0 (off) unless pressed and held... that would create a state of 1 (on)
Then Id make all them Blue or Yellow for consistency
and if that function was being called in a program (air on) the button would change color as a visual feed back.
just a PLC script addition
Dont want to have to write scripts for a button down and a button up but if I have too.
your defining a ON or Off delay action depending on how the output is handled from the button press
« Last Edit: May 10, 2014, 02:22:45 PM by Ya-Nvr-No »
« Reply #64 on: May 10, 2014, 05:30:11 PM »
M48 M49 do NOT appear to work.
(;-0 TP
« Reply #65 on: May 10, 2014, 10:55:40 PM »
There is a problem in this thread milling routine it blows mach4 up and currupts the corrd base.  when it gets to the First G03 call is when it happens. The XYZ values ALL goes from 0,0 to 6937.00000 something in both machine and user coords. Program locks up. AND yes it does it with or without the L5 call @N010
O02301 (THREADMILL 1.5-8 UNC)
(Single Point Thread Milling)
N1 T1 M06 (.5IN DIA THREADMILL )
N2 G00 G90 G40 G80 G54
N3 M01
N4 S5000 M03
N5 X0 Y0
N6 G43 Z0.1 H01 M08
N7 G91 G01 Z-0.5156 F50. (Switches to G91)
N8 G41 X0.25 Y-0.25 F20. D01
N9 G03 X0.25 Y0.25 I0 J0.25 Z0.0156
N10 I-0.5 J0 Z0.125 L5 (Repeats 5 times)
N11 X-0.25 Y0.25 I-0.25 J0 Z0.0156
N12 G40 G01 X-0.25 Y-0.25
N13 G90 G00 Z0.1 M09 (Switches back to G90)
N14 G91 G28 Z0
N15 M05 M09
N16 M30
« Reply #66 on: May 11, 2014, 12:59:55 PM »
hi All
When running Mach 4 mill using G95 (which I often do in Mach 3) it does not display in cuts per rev, is there a simple way round this?
Graham
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #67 on: May 11, 2014, 03:03:27 PM »
Terry,
the line repeat word (Lnn) is only active in subs, macros and canned cycles at the moment, it is on the list of to do's.
« Reply #68 on: May 11, 2014, 03:07:39 PM »
HI Graham, I figured that and it was not the problem the problem occured at the first G03 on line N9.
  •  2,785 2,785
« Reply #69 on: May 11, 2014, 03:10:43 PM »
There is but you need spindle feed back and Simulation in Mach4 has not got this, if you look at the YouTube video Brian and I did over Christmas that show CSS being tested, this was using G95 with G96.
