Hello Guest it is November 13, 2026, 05:57:37 AM
Author Topic: Mach 4 Bug Reports  (Read 882776 times)
0 Members and 6 Guests are viewing this topic.
Re: Mach 4 Bug Reports
« Reply #50 on: May 06, 2014, 06:26:07 PM »
goto safe zero button I created
mc.mcCntlMdiExecute(inst, 'G00 G90 X0 Y0 Z1 A0')
goto button
mc.mcCntlMdiExecute(inst, 'G00 G90 X0 Y0 Z0 A0')
look for editing the button script under the "left down script" for the button
though not sure why some scripts show left up and some show left down
not sure when you would use both
think it was whatever the boys felt like that day, but Ya-Nvr-No I might just find a need
« Reply #51 on: May 06, 2014, 06:37:03 PM »
THANKS Craig !
So many basics I need to pick up on.
Once you pointed me in the right dir., it looks MUCH more understandable.
Never looked under that little thunder storm before.
Russ
Offline smurph
  •  1,575 1,575
« Reply #52 on: May 06, 2014, 06:37:16 PM »
No, it is not protected.  But you sure did sniff out the way to find a lot of thing quickly!  That is the Lua script display that lists all of the scripts that are in the set.
So...  open up Mach 4, and then Operator->Edit Screen
Then click on the Goto Zero button.  You will see it's properties displayed on the left side of the screen.  Over the properties you will see a button with a lightening bolt.  Click on that.  This will change from properties to "events" and choose the "Left Down" script.  click on the ... button and it will open the Lua editor.
Steve
« Reply #53 on: May 06, 2014, 06:45:49 PM »
.... I might join in and be a contender in the upcoming Screen Design event, so don't teach me too much.
Nice work you are doing there, impressive !
Russ
Perfect Steve .... Thanks ! I was just thinking of opening that Lua script after changing the button to see if it changed there too, was assuming/hoping it would.
 I hate to ask dillweed questions, happy you guys are willing to stoop to my level.
I find learning something new very rewarding. I'm easily amazed. (dust in the sunlight is sometimes mesmerizing )
Manual ? ? ? We don't NEED no stinkin' manual.  :) (just kiddin')  ;)
Thanks again Guys,
Russ :)
« Last Edit: May 06, 2014, 06:47:52 PM by Overloaded »
« Reply #54 on: May 07, 2014, 12:48:09 AM »
build: 1754 (demo)
system: W7 x64, working on a local drive (no filenames longer than 80 chars)
occurrence 1:
- start fresh instance of Mach4
- click "Open G code file"
- enter non-existant filename into "File name" input box (e.g. testme)
result:
- error box "Load error" containing A general failure occurred while loading testme.tap.
- file testme.tap is actually created in file system
expected result:
- file is created and, if successfully, loaded into system
occurrence 2:
- repeat scenario 1 with different file names so that a few new files are created
result:
- program silently crashes back to desktop after next click on "Open G code file"
occurrence 3:
- navigate to directory containing valid G code files (e.g. GcodeFiles subdirectory)
- enter the name of valid G code filename including its extension, e.g. ArcTest.tap
result:
- program reports a "General failure loading" error
expected result:
- file gets loaded if user enters a valid filename including a valid (known) extension
- furthermore, Mach4 could try loading the file by the name entered by the user, then try to attach one of the file extensions
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #55 on: May 10, 2014, 04:53:49 AM »
Just try this and see what results you all get, what I get is very random.
« Reply #56 on: May 10, 2014, 06:13:30 AM »
In the screen designer, you can move controls by using CTRL+Arrow keys.
However, when you move them, their position in the properties window does not update until you click off them. So unless you count key clicks, you don't know where you're actually moving the controls to.
« Reply #57 on: May 10, 2014, 07:43:35 AM »
Howdy Graham,
I didn't find much info on G9. (new to me and not in the Mach3 list)
Is it a non modal that just invokes an exact stop position for each block that includes it while in CV mode ?
If so, I took the G2's out of your code and ran the file to more closely see the CV vs G9's at the corners and there is no exact stop where where G9 is called.
Nothing random here though ... very consistant.
new 1762 release
Russ
« Reply #58 on: May 10, 2014, 08:33:21 AM »
Build-1762
Run Ops, Single Block selected, Stepping through w/Cycle Start.
After initiating a move, If you happen to hit Cycle Start again before the current move is completed, the Cycle Start button will lock out, requires a Stop or Feedhold before continuing.
Russ
« Reply #59 on: May 10, 2014, 10:02:00 AM »
HIYA Craigs , a dual gated button like down/up is used when you need to create a function like an air blast. WHen you push the button down and HOLD(down) it activates the air blast. When you release (up) it shuts it off.
It could also work to jog the spindle (rotation)
