Hello Guest it is November 13, 2026, 05:57:48 AM
Author Topic: Mach 4 Bug Reports  (Read 882776 times)
0 Members and 6 Guests are viewing this topic.
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Mach 4 Bug Reports
« Reply #390 on: June 06, 2015, 02:57:09 PM »
This is strange, keeps popping up when I go into the mach configuration
« Reply #391 on: June 13, 2015, 06:42:26 PM »
After Loading MACH4 version 2491 with the ESS plugin, I noticed as soon as MACH4 comes up, my machine starts running away.  X,Y,Z all start moving full speed in the positive direction.  Keep in mind I never even enabled MACH4.  Just lucky I had an emergency stop button or it would have slammed into the end stops.  MACH4 on the previous several versions did not have this issue.  I have not changed the Ethernet SmoothStepper plugin it is the same April release.  Did anyone else notice this bug in version 2491?
Russ
Offline dude1
  •  1,253 1,253
« Reply #392 on: June 13, 2015, 06:59:47 PM »
check that the settings have not full in off I had that with Darwin re did the setting and it came right
« Reply #393 on: June 14, 2015, 08:41:22 AM »
I discovered the issue with MACH4 running away and it has nothing to do with the ESS plugin at all.  I had also installed the latest POKEYS plugin 1.67-1.2491 which is the designated plugin for MACH4 2491.  When that new POKEY plugin is enabled and you bring up MACH4 all axis' start moving rapidly in the positive direction.  I do not have the pulse engine in the POKEY plugin enabled at all.  The only thing I had was a matrix keyboard.  I tested this several times and confirmed this is clearly caused by the latest POKEYs plugin.
Russ
« Reply #394 on: June 20, 2015, 03:39:51 AM »
With the latest PoKeys plugin I am getting the axis movement on startup when using the simulator as the motion deivce. I run my machine with the Darwin parallel port driver. When I select Darwin as the motion device I do not get the axis movement at startup.
Althouh this is being tirggered by the PoKeys plugin I think is also has to be looked on as an issue with Mach4. When Mach4 is disabled I would expect all axis movement to be disabled as well.
Alastair
Offline dude1
  •  1,253 1,253
« Reply #395 on: June 20, 2015, 04:12:48 AM »
if you don't need sim remove it. it can make bad things happen on some computers
Offline Pedio
  •  200 200
« Reply #396 on: July 04, 2015, 10:48:33 AM »
If I use a button to select a jog increment (e.g., JogInc.2) the TextJogInc does not seem to know about the change. It continues to show whatever the last value that was achieved by using the btnCycleJogInc.
Am I missing a parameter or is this a bug.
« Reply #397 on: July 11, 2015, 10:39:58 AM »
anybody seen this behaver before  ? it happens when i hit cycle stop and hit cycle start again , in the middle of a circle .
Offline dude1
  •  1,253 1,253
« Reply #398 on: July 11, 2015, 03:40:20 PM »
you should not be hitting cycle stop use Feed Hold
« Reply #399 on: July 11, 2015, 04:27:18 PM »
But that doesn't mean that it's not a bug.
