Hello Guest it is November 13, 2026, 05:57:39 AM
Author Topic: Mach 4 Bug Reports  (Read 882776 times)
0 Members and 6 Guests are viewing this topic.
Offline smurph
  •  1,575 1,575
Re: Mach 4 Bug Reports
« Reply #260 on: October 09, 2014, 12:12:39 PM »
I ran my 2038 build for 12 hours straight to test.  It never stopped.  I'm running a Galil.  So it may be in your motion plugin.  What are you using?
Steve
  •  9,377 9,377
« Reply #261 on: October 10, 2014, 12:55:34 AM »
Hi Steve,
I am using Darwin and you are right build 2030 runs forever in simulation mode, only when running Darwin does it stop. Looks like the problem is over to Art  :)
« Last Edit: October 10, 2014, 06:53:35 AM by Tweakie.CNC »
« Reply #262 on: October 28, 2014, 01:13:28 PM »
Mach 4 2059 still won't allow Darwin to be licensed. I even went as far as downloading a new license file from the license manager. It downloaded as a .txt file and I had to change it to a .dat file to get Mach 4 to see it. I can jog 3 axises but that's it. Homing wont't work. I can't turn on my forward and reverse spindle relays
with M3 and M4 in MDI. Spindle won't turn on.
I looked in the history file and saw.
Failed to license feature M4_DARWIN
(mcDarwin)Darwin License has failed.
Do MDI
Then I looked in Mach 4 Help/System Information and saw Feature M4_mcDARWIN Unlicensed
So the Darwin plugin bug still isn't fixed.
Eric
« Reply #263 on: November 01, 2014, 07:49:27 AM »
Mach4 Build 2067 - XP
Load g-code.
Go into Screen Edit mode.
Change the number of lines in the g-code display.
Save Screen
Leave edit mode.
You can no longer rotate the toolpath display until you close and restart Mach4. This applies to all toolpaths on the different tabs.
« Reply #264 on: November 05, 2014, 04:14:51 AM »
downloaded the first time M4 (version 2067). I love what I see.
Unfortunately when I start m4 the outermost blue frame of the window is not showing up. (M4 is occupying the entire screen without the blue frame around.)
Therefore I can't resize the window. Any ideas how I can rectify it?
Thank Jakob
Offline smurph
  •  1,575 1,575
« Reply #265 on: November 05, 2014, 02:29:44 PM »
It may be in either full screen mode or the window (1024x768) is bigger than your monitor resolution.
In the view menu, there is a full screen toggle item.  If you screen res is too small, you will have to use the keyboard to resize it.
Steve
« Reply #266 on: November 06, 2014, 02:38:09 AM »
[/quote]
Steve
Thank you Steve,
it was my fault. Did not recognize Alt+Enter was the shortcut to solve this isue.
Jakob
« Reply #267 on: November 07, 2014, 07:17:15 PM »
Hi guys, for what it's worth..
mach4 build 2075 unstable locks up
Darwin 1.2075
szAppName : Mach4GUI.exe     szAppVer : 1.0.0.1     szModName : hungapp
szModVer : 0.0.0.0     offset : 00000000
rgds
Charles
Offline smurph
  •  1,575 1,575
« Reply #268 on: November 07, 2014, 08:49:47 PM »
Is that the latest Darwin?  Art told me it was running fine.
Steve
« Reply #269 on: November 07, 2014, 11:17:29 PM »
Darwin install file named "DarwinSetup2075.exe"
charles
