Hello Guest it is October 23, 2026, 04:11:05 PM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1460823 times)
Re: Mach3 2010 Screenset - Now available
« Reply #130 on: March 10, 2013, 08:11:55 PM »
I've heard that there may be macro bugs in .66, although none of my users have reported any to me.
 If you run into any problems, try going back to .062.
It's only 9:00PM here. You should have the screenset files in your mail.
« Reply #131 on: March 10, 2013, 08:21:19 PM »
HA HA, fantastic service!! Thank you kindly... Now for some DUMB newbie questions.
1/  Where does the installer download the manual too?
2/ When I go to View/Screens; which file is the correct screen, as several are listed...2010-4.set, 2010-4x.set (what are these?
Told you they were dumb questions lol
« Reply #132 on: March 10, 2013, 08:30:49 PM »
1) Look in your Start menu. ( This was mentioned in the email I sent ;) ) Should be in your \Mach3\Documentation\ folder
2) I think the manual explains it, but the (x) versions have a larger diagnostic screen with space for extra LED's for the user to customize. 99% of users don't need these.
2010.set is the 3 axis screen, and 2010-4.set is the 4 axis version. The widescreen versions should be self explanatory
« Reply #133 on: March 10, 2013, 09:04:48 PM »
OOPs... yeah was so exited to get it so quick I didn't read that bit   ;D.  OK I'll stop bugging you ( I'm off to do some good reading) >:D
« Reply #134 on: March 10, 2013, 10:06:07 PM »
 Gerry!     I hope u r awake still I have done everything exactly as the manual describes.... AND I GOT NOTHIN the motors wont jog, (yes i have jog button on) I have replaced files in macro folder as described... i even made back ups as instructed.  >:D  ... ANY IDEAS??  The DRO dont even move on my profile. I opened up MachMill profile and it all seems fine!.  Any help appreciated  thanks
« Last Edit: March 10, 2013, 10:16:49 PM by warped »
« Reply #135 on: March 11, 2013, 06:08:09 AM »
It sounds like you're somehow loading a different profile that doesn't have any motors enabled. All you have to do to change to the 2010 Screenset is go to View> Load Screens and select the .set file.
« Reply #136 on: March 12, 2013, 04:07:48 AM »
Yeah doing that. I noticed on the bottom right corner of the screen the green button is flashing oink. Could that mean anything?
Sorry its not flashing " oink"   :P   its flashing green/pink
« Last Edit: March 12, 2013, 04:18:57 AM by warped »
« Reply #137 on: March 12, 2013, 04:17:17 AM »
 figured it out ... alll i did was press the top far right button;  looks like a re-do button. ALL WORKS A TREAT  :D
Guess I'm off to watch those tutorial videos,, AGAIN      Find out what that little majic button is  >:D
« Reply #138 on: March 12, 2013, 06:38:30 AM »
It's the Reset button.
Offline Bloy
  •  158 158
« Reply #139 on: March 21, 2013, 10:23:21 AM »
Hello Gerry,
 I've been configuring your screen and noticed the RefAll sequence (M884.m1s) was different than the one I used.
This is your original:
DoButton( 24 )
'Code "G53 G0 Z-1"
'While IsMoving()
'Wend
DoButton( 23 )
'Code "G53 G0 Y1"
'While IsMoving()
'Wend
DoButton(22)
'Code "G53 G0 X1"
'While IsMoving()
'Wend
This is the one I inserted(replaced):
DoButton( 24 )
'Code "G53 G0 Z-1"
'While IsMoving()
'Wend
refcombination( 19 )
Art had included this, I just used it.
Basically, all it does is Ref both X and Y axes simultaneously after first referencing Z.
It works as intended, but was just wondering if it will create problems anywhere else in your screen functions.
John(Bloy)
« Last Edit: March 21, 2013, 10:30:12 AM by Bloy »
