Hello Guest it is October 23, 2026, 02:07:49 PM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1460646 times)
0 Members and 64 Guests are viewing this topic.
Re: Mach3 2010 Screenset - Now available
« Reply #220 on: September 21, 2014, 08:04:17 AM »
I think so.
Send me an email and I'll get you something to try.
« Reply #221 on: September 21, 2014, 08:36:27 AM »
U have a PM :)
« Reply #222 on: September 22, 2014, 10:02:49 AM »
By the way Ger
Have I done something wrong?
When ever I try to use the rapid movement to 0,0,0 thenZ axis retracts beyond limit switch and beyond 0, and slams against the top, triggering the drive over current.
Should I run a soft limit on this, or something?
I have uploaded a video of the initial script running. Very nice even.
https://www.youtube.com/watch?v=CEadul2Wv1Y&feature=youtu.be
« Last Edit: September 22, 2014, 10:07:17 AM by IN-WondeR »
« Reply #223 on: September 22, 2014, 06:43:41 PM »
Do you have a Z home switch?
Do you have Safe Z enabled and set correctly?
If you have a home switch, and are using safe Z, make sure Safe Z is set to use Machine coordinates, and make sure the value is correct.
If you're talking about the Goto Zero, then that is the default Mach3 goto zero function.
« Reply #224 on: September 24, 2014, 11:31:13 AM »
Hi Gerry
Is it possible to set the fixed touch off plate to only move in the Y axis, I was planning og attaching my fixed touch off plate to the gantry sides, so it moves along the X axis along with the gantry, thus only needing the Y wagon to move to the side to do a tool zero operation.
If this is not possible, then I'll figure something out, but it would be easier, since moving 1000-1400mm in one direction each time will take up some time in the cutting sequence.
What a great idea...  Please update with the specifics if you get this working...
« Reply #225 on: September 24, 2014, 11:50:37 AM »
Yes, he got it working, and posted a video of it on YouTube. I can get the link later if he doesn't post it.
« Reply #226 on: September 24, 2014, 01:13:22 PM »
I have not gotten around to putting the M6end part onto the machine, but here's the video with Gerry's changed initial tool setting.
« Reply #227 on: September 29, 2014, 12:39:30 PM »
So what is involved in changing things in Gerry's screenset (Mach 3) to do this?
Now I have to brainstorm a little to see if there is a way to mount the touch plate on my machine...  This would completely remove the risk of ever running a bit into the fixed touch plate...
« Reply #228 on: September 29, 2014, 01:11:37 PM »
It's a simple change in the M881 and M6End macros.
« Reply #229 on: September 29, 2014, 02:25:18 PM »
Let me look into if it will work for my machine (mechanics wise) and if so, I'll get more info...
On a semi related subject, would it be hard to add a button that homes to x and y but not z?
or a software switch that changes how the home command behaves (ie include or exclude axis)
