Hello Guest it is November 22, 2026, 07:19:27 AM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1510557 times)
Re: Mach3 2010 Screenset - Now available
« Reply #180 on: October 21, 2013, 02:43:36 PM »
I thought I did but I'll do it again. Thanks again Ger
« Reply #181 on: October 21, 2013, 03:12:08 PM »
You may have edited the file in the macros\2010\ folder.
« Reply #182 on: October 21, 2013, 03:47:05 PM »
I went back and re-copied all of the macros from the 2010 folder and overwrote the ones in my configuration folder and it worked. Not sure what happened but I did edit the correct file in the correct folder but maybe I didn't get all of the necessary macros copied over before. Thanks agian Ger. This screenset is just awesome.
« Reply #183 on: October 31, 2013, 09:04:31 AM »
Hello
I have purchase the screenset couple days ago. I run the installation file and start Mach3. When I try to load the screenset it shows "bitmap goes here" and it loads like only 5% of the graphics. Basically its not usable because nothing is on the screen.
« Reply #184 on: October 31, 2013, 10:36:51 AM »
It sounds like you installed it to the wrong folder. Uninstall it, and reinstall it, making sure the file path points to your Mach3 folder.
Under Mach3\bitmaps, you should see a 2010 folder. If not it's installed in the wrong place.
« Reply #185 on: December 11, 2013, 01:37:42 AM »
How can i setup the probe script to use 2 diffrent inputs?
I want to have a plate for tool change.
And one touch probe for probing.
The Plate input is set to low, and the probe is set to high.
« Reply #186 on: December 11, 2013, 07:32:13 AM »
You can't. Only one input works with probing. If there is a way, I don't know how to do it.
Offline Vogavt
  •  260 260
« Reply #187 on: December 11, 2013, 09:09:36 AM »
If you're not using the "index" pin for rpm check, couldn't you set it up to react to the signal seen. Just thinking out loud here and I've only had one cup of coffee this morning!
Sent from my DROID RAZR using Tapatalk
« Reply #188 on: December 11, 2013, 09:10:40 AM »
Solved it....
Just added a brain witch turned on probe input when Input 1 activate.
« Reply #189 on: December 11, 2013, 08:43:45 PM »
Hi Der Synth
I have the same issue I have been battling with - I want to keep my Auto-Zero/Touch Probe connection - and - also run a Digitizing Probe - however - Mach3 only has one Probe input as you have noted.
Could you possibly take pity on an old man and post your 'brain' for myself and fellow sufferers please.
Eternally grateful, etc, etc.
Noel   ;D ;D ;D
