Hello Guest it is October 23, 2026, 03:12:36 PM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1460756 times)
0 Members and 6 Guests are viewing this topic.
Re: Mach3 2010 Screenset - Now available
« Reply #490 on: June 27, 2017, 09:45:11 PM »
Hi Ger, thanks for all your work, I am really liking the screenset. I am having one small problem right now with my toolpath outputs from Fusion 360 adding a tool change at the beginning of the file similar to the way a Vectric post process does. I am wondering if it's possible to use your Vectric post processors with Fusion to remove the initial M6 command or if I need to keep editing it by hand. Thanks. Luke
« Reply #491 on: June 27, 2017, 10:04:29 PM »
No, you'll need to edit it by hand, as the post processors are not compatible.
I haven't had a chance to learn to write Fusion post processors.
« Reply #492 on: June 27, 2017, 10:06:17 PM »
Ok thanks, It's still awesome and there's an option in Fusion to open your file in an editor on export so the workflow is pretty smooth.
There's also a "use M6" option which can be turned off in "properties" when you post process but I'm afraid I'll leave it off one day when using multiple tools.
« Last Edit: June 27, 2017, 10:19:48 PM by Robotintheforest »
« Reply #493 on: June 28, 2017, 12:57:11 AM »
Well I did a little more digging and found one on the Autodesk forum...
https://forums.autodesk.com/t5/hsm-post-processor-forum/mach-3-alternative-post-mach-3-2010-screenset/m-p/6296407/highlight/true#M9418
I haven't run a file but at first glance the code looks good, no initial tool change and an 883 macro at the end.
« Reply #494 on: June 28, 2017, 05:38:25 AM »
Thanks for finding that. I'll take a look later today.
Offline Chaz
  •  48 48
« Reply #495 on: June 28, 2017, 02:47:22 PM »
Great product, why didnt I buy it earlier?
Can anyone tell me why I have no toolpath showing?
Ive unchecked all the graphics options, decent PC with decent graphics card, any ideas please?
« Reply #496 on: June 28, 2017, 02:59:42 PM »
Try the icon in the toolbar with the black/white squares, which toggles the toolpath on and off.
Offline Chaz
  •  48 48
« Reply #497 on: June 29, 2017, 06:01:06 AM »
Thanks, will try that tonight when I get home.
Offline Chaz
  •  48 48
« Reply #498 on: June 30, 2017, 06:32:24 AM »
I tried this last night, no difference.
Are there any other graphics / drivers options I need to change or similar?
I am using a basic Nvidia GT210 as a budget card on this machine. Thanks.
« Reply #499 on: June 30, 2017, 08:07:28 AM »
Are you sure that your code is not just off to the side, where you can't see it?
I don't recall ever hearing of anyone not having the toolpath showing? Is there anything in the window at all? Can you post a screenshot?
