Hello Guest it is October 23, 2026, 02:07:55 PM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1460648 times)
0 Members and 62 Guests are viewing this topic.
Re: Mach3 2010 Screenset - Now available
« Reply #190 on: December 11, 2013, 08:52:45 PM »
Try this. Make sure it's enabled, and assign the probe to Input #1 in Ports and Pins.
I didn't test this on a machine, but it works when I emulate Input 1 with a keystroke.
« Reply #191 on: December 11, 2013, 11:22:04 PM »
Many thanks
I will give it a go.
Noel
Offline khalid
  •  213 213
    • My Wood carving
« Reply #192 on: December 31, 2013, 09:19:53 PM »
Gerry, I can't find the Mach3 version 3.43.062 in download section. Can you direct me the download link pls.
« Reply #193 on: December 31, 2013, 09:49:06 PM »
Offline khalid
  •  213 213
    • My Wood carving
« Reply #194 on: December 31, 2013, 10:43:09 PM »
Thanks Gerry, i dont know why i missed the last tab in the new website of Mach3 :)..I got it thanks:)
« Reply #195 on: January 04, 2014, 05:05:54 PM »
Has anyone ever used the Mach 3 2010 on a Ez-Router table?
« Reply #196 on: January 12, 2014, 08:24:06 PM »
This looks like something I'm very interested in.  A couple questions;
Can I assume since this is just a screen that it would have no affect on plugins?  I'm going to be adding the XBox 360 controller for jogging as soon as the controller I ordered arrives.
I watched all of the videos and read through this entire thread.  I noticed in the video's you are using a wood router so have two pieces of metal for your surface contacts.  I did hear you reference using the actual part for a mill for the first contact.  I assume you're just using a ground so you could ground to the workpiece (assuming it conducts) and perhaps a know thickness piece of aluminum on the top of your vice, right?
Mark
« Reply #197 on: January 12, 2014, 09:00:28 PM »
Correct, it should work with any plugins.
Can't really answer the second, as it depends on how your mill is wired. On my router, the spindle is grounded. You can also make plates out of PCB or similar material that are isolated from the machine frame.
« Reply #198 on: January 17, 2014, 04:42:09 AM »
Quick question. I don't think I have changed anything in my settings but I used to be able to click on the FRO numbers and type in a new feed rate. Now when I click on the number a calculator looking window pops up and I have to click on each number to enter a value. This is very annoying when I need to change the feed rate on the fly.
I could not find any answers with the search tool in this forum. I try to find the answer before posting but I think I need help on this one.
Thank you everyone in advance for your help.
Mike
« Reply #199 on: January 17, 2014, 06:24:32 AM »
I don't have Mach3 here, but check under the Operator menu for the option to turn it off.
