Hello Guest it is October 23, 2026, 04:12:46 PM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1460862 times)
Re: Mach3 2010 Screenset - Now available
« Reply #340 on: April 14, 2015, 05:34:26 PM »
Hello Gerry,
       I have a question about using offsets. Lets say I have G55 set to 0,0. and G56 set to23,23 mm. I goto the the off sets tab and select G56. How do I get the machine to move to that location?  Thanks.
Charlie
Regards
Charlie M.
« Reply #341 on: April 14, 2015, 09:57:16 PM »
Where do you want to move to?
The offset isn't a location, but a shift to the coordinate location.
If you want to move anywhere, you can use the MDI to move the machine.
I recommend you watch the homing, limits and offsets video here:
http://www.machsupport.com/videos/
« Reply #342 on: April 15, 2015, 04:24:01 AM »
The standard mach screen has this button called goto z. what it does is make the machine goto zero position. When I use off sets in the standard screen the dros change to the off set coordinates and when I hit the goto z button the machine zeros at the off set position. I would expect your screen set to work similar.
Regards
Charlie M.
« Reply #343 on: April 15, 2015, 06:56:18 AM »
The goto zero button is on the right side of the toolbar. (Left of the "P") Look in the manual for a description of the toolbar buttons.
« Reply #344 on: April 15, 2015, 04:22:49 PM »
 Hi Gerry,
           Thanks. That seems to work. It would be nice to have something like a balloon message when you hover the buttons to tell what they do.
Regards
Charlie M.
« Reply #345 on: April 15, 2015, 04:50:36 PM »
Yes, it would, but Mach3 doesn't have that option. Sorry.
« Reply #346 on: April 15, 2015, 06:31:18 PM »
 What do you mean Mach3 does not have that option? I did it just as I described it to you in the standard mach screen set.
Regards
Charlie M.
« Reply #347 on: April 15, 2015, 06:36:11 PM »
Can you show me a screenshot? I've never seen a tooltip in Mach3. And there's no way to add them with the screen editor.
« Reply #348 on: April 15, 2015, 06:48:56 PM »
Oh no sorry I misunderstood you. I don't have tool tips in the original mach screen. It was just a suggestion. I figured you programed the screen set in Vb or something.
Regards
Charlie M.
« Reply #349 on: April 15, 2015, 06:53:16 PM »
No, it's done in a screen designer. I meant that Mach3 doesn't support tool tips. I don't believe that Mach4 does either, but I made a feature request for them.
The goto zero in the 2010 screenset is exactly the same as in the regular screenset.
