Hello Guest it is November 12, 2026, 03:32:20 PM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1504787 times)
0 Members and 6 Guests are viewing this topic.
Re: Mach3 2010 Screenset - Now available
« Reply #280 on: December 13, 2014, 10:23:44 AM »
How do you enter more than one line at a time in MDI?
As for the probe not working, are you sure it's not an electronic issue?
« Reply #281 on: December 13, 2014, 04:36:41 PM »
Sorry Ger,
What I meant by more than one line is enter a line press enter and as it is going to that command enter a new line and press enter. It was locking up the moment you pressed enter on the second line of input and the DRO though it was still moving but the motor would stall. That was corrected by taking it off continuous and putting it in step on the jog tab. Checked all lines with multi-meter and they all show okay, nice clean tone on all of them.
Will let you know what comes out of the reinstall and hopefully it was just one of the libraries or files that got corrupted and needs repaired/replaced. If my explanation above is not clear please let me know.
Michael
« Reply #282 on: December 16, 2014, 12:45:32 AM »
Hi ger.
Do you possibly have a PostProcessor for HSMExpress by HSM Works for this screenset??
« Reply #283 on: December 16, 2014, 07:36:53 AM »
No, but I just started using Fusion 360, which I think uses the same post processor? No idea when I'll have time to make one. A few months at least.
« Reply #284 on: December 16, 2014, 08:12:32 AM »
Can I use the same postprocessor that is used by Aspire???
« Reply #285 on: December 16, 2014, 10:08:21 AM »
No
« Reply #286 on: December 16, 2014, 07:13:29 PM »
I am new to the 2010 screen set and have an installation question. I installed the 1920x1080 screen set as I have a big monitor.  All of the screens work OK but the numbers are not centered in their appropriate boxes. I tried other screen set resolutions but the same thing occurred.  When I look at all of the youtube videos the numbers seem to be perfectly centered in the boxes.  Am I doing something wrong or is this normal.
Dick
« Reply #287 on: December 16, 2014, 07:54:56 PM »
Go to General Config, and uncheck "Auto Screen Enlarge", and close and restart Mach3.
If that doesn't help, send me a screenshot of what you're seeing.
« Reply #288 on: December 16, 2014, 08:33:25 PM »
Hi Ger:
I just emailed you a screenshot of what I am seeing.  I forgot to mention that I tried all of the 2010 screenset resolutions and they all do the same thing. WI wasn't sure how to send the screenshot via the forum but I might have figured it out.
thanks for your help
Dick
« Reply #289 on: December 18, 2014, 03:59:08 AM »
I'm new to CNC and I just installed your 2010 screen set.  When I set my soft limits on Z, how do I calculate the min. max. throw?  Do I put a bit into the router and touch off to the bed or a piece of material?  I'm really confused about figuring these numbers.
