Hello Guest it is October 23, 2026, 02:07:50 PM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1460646 times)
0 Members and 64 Guests are viewing this topic.
Re: Mach3 2010 Screenset - Now available
« Reply #580 on: March 20, 2019, 05:36:54 AM »
Akira,
Are you using a Chinese motion controller by chance? If so, download and try using the macros at the bottom of the page here:
Direct Link:
http://www.thecncwoodworker.com/downloads/mach3/Chinese%20Motion%20Controller%20macros.zip
« Last Edit: March 20, 2019, 05:39:04 AM by ger21 »
« Reply #581 on: March 20, 2019, 07:00:43 AM »
hi, most of my stuff is chinese, a PERK or DRAWBACK for living there, but from what i believe my usb controler is maybe russian, at leats thats what the website looks like haha, this is my board
https://www.nvcnc.net/zkmotion.html
thaks i will try them now, should i just copy them to the macro folder and over write the original ones included with the installer (im sorry im not really sure how macros work and im glad there is people like you there to write them)
its a ZKmotion controller.. im very surprised at how well it works, and how simple it is to set up, all tho every now and then it seams to have a problem where in the middle of a job  mach 3 says my axis are still running but theirs no movement from the steppers, but matbe one day i will figure that bug out
« Reply #582 on: March 20, 2019, 07:08:22 AM »
I've never seen that controller.
Yes, overwrite the macros in the Mach3\macros\yourprofile\ folder.
Most of the plugins for Chinese controllers do not handle probing properly, so the macros don't work properly.
« Reply #583 on: March 20, 2019, 07:14:31 AM »
as little as i know i think its dong a good job for $100, just installed the new macros and first test was flawless!the joy on my face right now, and the bewilderment of my wifes is a drastic difference ... thank you for the quick response  and your continued hard work
just one quick question,, is it possible to use different plate thicknesses for the fixed and movable plate... other wise ill just buy some machined stock
« Reply #584 on: March 20, 2019, 07:59:17 AM »
The fixed plate thickness does not matter. The macro saves the location of the top face after the Initial Auto Zero.
According to their website, that's actually a DDCSV1 controller, which I think are pretty common.
Glad it's working. Let me know if you have any other questions. You can always email me as well.
« Reply #585 on: March 20, 2019, 11:28:12 AM »
thank you
« Reply #586 on: April 29, 2019, 07:41:09 PM »
I have a problem with my spindle spin up before cut is to short and it crashes my machine . is there a way to increase the wait before spindle spin up .
« Reply #587 on: April 29, 2019, 08:01:06 PM »
Config > Ports and pins > Spindle Tab.
« Reply #588 on: May 13, 2019, 01:08:33 PM »
Hi I'm having a strange problem where when i move the display screen around my machine stops and i have to cycle start again but am not losing communication i can just cycle start and all is well as long as i don't move the screen around. any ideas ?
« Reply #589 on: May 13, 2019, 01:19:08 PM »
Don't move the toolpath view while the machine is running. I've never heard of it stopping, but it will typically cause the machine to stutter.
Just a Mach3 limitation.
