Hello Guest it is November 17, 2026, 11:05:09 AM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1507394 times)
0 Members and 8 Guests are viewing this topic.
Re: Mach3 2010 Screenset - Now available
« Reply #50 on: December 06, 2011, 04:43:40 PM »
I use Screen4, not MachScreen, but it looks OK? Not sure why it's not working for you??
« Reply #51 on: December 06, 2011, 05:50:26 PM »
Yeah, weird. I cant figure it out either.
Oh well, problem solved. If anybody else has a problem like this, I'd suggest copy-pasting the macro code into the button, and setting the button to 'Execute Basic Script'. Worked for me. Once I get a touch probe, I will test all the other macros to determine if it is macro's in general or if it is just one button.
« Reply #52 on: December 06, 2011, 05:53:48 PM »
NEVER MIND. User error!
(I'm an idiot and was confusing my two (separate) Mach3 installations. I hadn't installed the macro files into my profile correctly.)
Thanks Gerry. Still loving the screenset. Well worth the couple of bucks.
« Reply #53 on: December 06, 2011, 06:32:29 PM »
don't know if it's good or bad, but that's the problem 99% of the time ;)
« Reply #54 on: January 27, 2012, 10:29:03 AM »
Nicely done Ger, but one question about the videos and laptop use,
 you said you had a button set up to act as the probe, I have tried the emulate check mark on the probe input, the led lights, but it doesn't stop the virtual simple zero or tool change zero.
 Any hints would be helpful, I'm using mach3 3.042.040 on vista, on my laptop
I thought familiarizing myself on my crashproof virtual laptop machine would be ideal.
thanks again, nicely done ;)
« Reply #55 on: January 27, 2012, 10:38:22 AM »
Do you have the parallel port driver installed? That's all I can think of??
Offline IBBruin
  •  13 13
  • Poppa D
« Reply #56 on: February 19, 2012, 06:02:57 PM »
« Last Edit: February 19, 2012, 06:04:56 PM by IBBruin »
« Reply #57 on: February 27, 2012, 04:15:05 PM »
ger:
 I really like the "2010 Screenset" and the tool change works like a dream. Just one request........ Is there a way to make the 'Line #' window show more digits. Sometimes I need at least 6 digits showing when making large reliefs.
« Reply #58 on: February 27, 2012, 05:44:05 PM »
Send me an email and let me know what .set file you're using.
French version now available
« Reply #59 on: March 17, 2012, 09:58:23 AM »
Thanks to Jean-Philippe CIVADE, the French version of the 2010 Screenset is now available, and there's a link on my site to a French version of the page, with French version screenshots.
« Last Edit: March 17, 2012, 10:10:41 AM by ger21 »
