Hello Guest it is October 23, 2026, 05:17:39 PM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1460983 times)
Re: Mach3 2010 Screenset - Now available
« Reply #60 on: May 06, 2012, 12:44:36 PM »
HIYA Gerry Is there a demo version of the screenset,  We were sitting around talking about IF anyone had created a HASS or Mazak looking screenset . Yours came to mind. Just wanted to compare yours to those others(;-)
« Reply #61 on: May 14, 2012, 07:16:35 AM »
Hello ger21 I bought from you screensets and very happy to use it. tell me has it possible to manage A  axis in the manual mode with the keyboard of your computer as other axes? I apologize for my bad english
« Reply #62 on: May 14, 2012, 10:42:05 AM »
Just go to Config >Hotkeys and set the keys you want to use for the A axis.
« Reply #63 on: May 14, 2012, 02:16:21 PM »
thanks for the quick reply I now have what he wanted. I apologize for my bad english
« Reply #64 on: June 11, 2012, 07:59:34 AM »
I have installed the screen2010 (from last August) and very happy to run my machine with its big tool path display.
BTW
Recently, I try to get signal of actual spindle revolution. As a test, I have assigned INDEX input to PIN#15.
It could be shown on screen 1024 by "Emulated" with a hotkey.
My question is;
 Is there any way to display the actual RPM on the screen2010 ?
"RPM" display on the screen2010 is the value of M3 command (e.g. 6000 from M3 S6000), not the actual. Is this correct ?
Thanks in advance for your kind help/assistance.
« Reply #65 on: June 11, 2012, 08:56:20 AM »
Do you need to see both the commanded speed and actual? I modified a screen for someone to do that. Send me an email explaining what you want and I'll se what I can do.
« Reply #66 on: June 11, 2012, 10:39:38 AM »
Hi GER
I Have your screenset which i paid for just reset up my machine  and i have set up touch plates when i press to do a part i keep getting error message ERROR# EXPANDED FILE NOT FOUND AT : C:/Mach3/Screenset/Macros/2010x.set/master/headers/copyright
and Licences Notice m1s.
have you any idea whats the problem.
thanks  johnmb1946
« Reply #67 on: June 11, 2012, 10:51:08 AM »
That message is from the MSM screenset, not mine.
« Reply #68 on: June 12, 2012, 08:03:03 AM »
thanks gerry
buy the way how do i get the spindle to turn on after a tool change
the gcode program has a m3 in but spindle does not start it seems to miss starting it.
thanks
john
« Reply #69 on: June 12, 2012, 09:25:47 AM »
Can I see the code? And your .xml?
It should start if there's an M3. Does it start at the beginning of the g-code?
