Hello Guest it is October 23, 2026, 04:11:30 PM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1460834 times)
Re: Mach3 2010 Screenset - Now available
« Reply #620 on: May 22, 2022, 11:43:10 AM »
I would add some small invisible (transparent) buttons somewhere on the screen where no you normally wouldn't click them, and add shortcuts to the buttons.
« Reply #621 on: May 22, 2022, 12:37:56 PM »
Thank you Ger! I'm going to investigate...
« Reply #622 on: May 23, 2022, 01:53:44 AM »
I've put offscreen 4 image buttons, setup as folllowing :
Feed-   OEM Code 109 (hot key 121)
Feed+   OEM code 108 (hot key 122)
Speed-   OEM Code 164 (hot key 109)
Speed+   OEM Code 163 (hot key 107)
Oemcodes have been took from mach3 stock screen with screen4.Exe.
And the magic happened! It works fine.
I've attached the 1024x768 and full HD patched french screenset.
Again, thanks Ger.
Cheers JPC
« Last Edit: May 23, 2022, 01:56:45 AM by ewidance »
« Reply #623 on: June 30, 2022, 01:42:02 AM »
Hello everyone,
I have purchased screenset 2010 and it works very well, for the moment, with a Chinese XHC MK4 Ethernet card.
It is necessary, of course, to change the macros for the Chinese card, as it is explained and proposed by the developer.
eveb
« Reply #624 on: March 21, 2023, 08:13:20 AM »
Wondering if anyone can help, I'm using 2010 screenset. When I go the auto zero the machine probes my non fixed probe x2 and then moves to my fixed probe but only probes it the one one time. It used to work perfectly and I would get the odd time it would do this but now it happens more and more. Any ideas?
« Reply #625 on: March 23, 2023, 06:14:41 PM »
When it probes it one time, is it finished, or is there an error message? If it's finished, then your probe input is probably triggering twice due to noise.
« Reply #626 on: March 23, 2023, 06:58:29 PM »
Thanks for the reply. It just probes it once, retracts and then pauses and continues like it has carried out the second probe, but the probe doesn't actuate in mach 3. I'll have to look into noise issues I guess ?
« Reply #627 on: March 23, 2023, 08:12:25 PM »
If it continues, then that usually means the macro finished, which means it triggered twice. When noise triggers the input, it usually happens so fast you don't see it.
