Hello Guest it is November 18, 2026, 09:14:09 AM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1508336 times)
0 Members and 18 Guests are viewing this topic.
Re: Mach3 2010 Screenset - Now available
« Reply #230 on: September 29, 2014, 03:33:43 PM »
Read the 2010 Screenset manual. It explains how to modify the homing by editing the macros. Last part of the manual.
« Reply #231 on: September 29, 2014, 04:02:02 PM »
will look for it... been a couple years since I looked at it...
If it's not on my computer is it on your page?
« Reply #232 on: September 29, 2014, 04:08:02 PM »
Yes, there's a link to it on my webpage, and also in your Start menu where you have the screenset installed.
« Reply #233 on: September 29, 2014, 06:07:55 PM »
awesome
« Reply #234 on: October 05, 2014, 02:06:53 PM »
I have mach 3 screenset 2010. recently i have been having issues with the touch off. i am in G54 and i have zeroed x, y and z. when i got to use the double touch off the z axis will move about 20 thousands and the retracts and starts to head off to my fixed plate. it never touchs my work height plate. when it gets down to my fixed plate it lowers about 20 thousands (never touching the fixed plate ) then it comes back and wants to run the g code. i have closed mach3 and saved the fixture and not saved the fixture. but it still wont go all the way to either touch pad. i have checked all my settings nothing has changed. i'm not sure what to do. i have even shut down my computer and restarted, same problem.
« Last Edit: October 05, 2014, 02:11:13 PM by krugshouse »
Safe machining everyone
« Reply #235 on: October 05, 2014, 02:26:59 PM »
Most likely, noise is triggering your probe input.
It's been the case in 100% of users who see this or something similar.
« Reply #236 on: October 05, 2014, 02:34:05 PM »
thanks i will change out my wires for the plates to a shielded wire. will let you know if that doesn't work.
« Reply #237 on: October 05, 2014, 02:38:33 PM »
In a lot of cases, users add a capacitor across the input if the wiring change doesn't help.
« Reply #238 on: October 06, 2014, 05:30:06 PM »
Well i changed the wiring to my touch off and fixed plates to shielded cables. i am still having the first part of my problem. the first touch off to the work piece still moves about 20 thousands. the second half of the cycle works ok now gantry moves over my fixed plate and the z axis drops down and the bit touches off my fixed plate. i changed my BOB also and that didnt make any differance. i thought maybe it would. i'm a bit confused the touch off sequence has worked good up till last week. i did not change anything on my machine or to the software. should i try reinstalling the sceenset? if it comes down to needing a capacitor what size should i use. i have a Radio Shack a few miles from the house.
« Reply #239 on: October 06, 2014, 06:01:01 PM »
Are you seeing a message stating that probing is complete? If so, then it's almost certainly noise.
I doubt that re-installing anything will make any difference. The only way that would help is if there's a problem with the M881 macro. I've never heard of that happening.
You could try creating a new .xml file from scratch and see if that makes any difference. I have seen .xml files go bad. But I don't think it would affect the operation of the macro, but I guess it's possible.
I don't really know a lot about electronics, but I think it's either .01uF
