Hello Guest it is October 30, 2026, 11:18:58 AM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1485786 times)
Re: Mach3 2010 Screenset - Now available
« Reply #600 on: May 22, 2020, 11:36:54 PM »
Hi I bought the 2010 screen set two days back. Have not heard anything since. I sent an email to the address as well....
Where so I download this from?
« Last Edit: May 22, 2020, 11:39:32 PM by scalci »
« Reply #601 on: May 23, 2020, 09:00:28 AM »
I replied to your PM.
« Reply #602 on: July 05, 2020, 02:24:58 PM »
Been using screen set fine for months but now initial zero doesn't re touch the fixed plate at the reduced feed rate it just probes it once. I have had this happen before during tool changes but not on initial setup. Using the chinese macros.
« Reply #603 on: July 05, 2020, 06:23:23 PM »
First thing I'd try is replace the .xml file with a known good backup.
« Reply #604 on: July 06, 2020, 06:20:16 AM »
I have uninstall and reinstalled everything and it just the same
« Reply #605 on: July 06, 2020, 04:55:28 PM »
Sorry, I don't have an answer.
If it was working before, then something must have changed?
Does it never work with tool changes, or just sometimes?
I'd have to guess that it's an issue with the controller.
If the macros don't work correctly 100% of the time, then there's a problem somewhere.
Two Questions.... Z-Zero retract height and re-download
« Reply #606 on: September 01, 2020, 03:47:16 PM »
Going on 10 years, what a cool screenset!
I am setting up the screen-set on my new machine. Is there a place I can download the latest files? Past that, when I use the z zero functions, my head is retracting all the way to the top of the throw before coming back slowly for the more accurate measurement. Does the retract height relate to a setting somewhere in the mach settings?
Thanks!
« Reply #607 on: September 06, 2020, 11:17:27 PM »
I got it working woo woo!
Anywhere there was a call to GetVar:
Code: [Select]
ZNew = GetVar(2002)
I swapped it out for a Sleep and GetOEMDro
Code: [Select]
Sleep(250)
ZNew = GetOEMDro(802)
« Reply #608 on: September 07, 2020, 07:23:39 AM »
I have a full set of macros on my website for Chinese controllers that do not use the GetVar() function.
They don't work with all Chinese controllers, but they do work for many of them (I think).
« Reply #609 on: September 07, 2020, 11:07:46 AM »
I thought I was using the updated macros but it turns out I downloaded the Auto Zero G54 through G59 modified macros instead of the Modified Macros for Chinese Motion Controllers .
Good to go, thank again.
