Hello Guest it is October 23, 2026, 03:11:19 PM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1460723 times)
0 Members and 6 Guests are viewing this topic.
Re: Mach3 2010 Screenset - Now available
« Reply #570 on: March 18, 2019, 08:23:24 PM »
wow i just install the 2010 and are having many problems i must be missing something . ill start with i have a blinking light at bottom right . i can't home the machine , can't jog . i can go to view and change the screen to screen24 then i see mach3 where i can home can jog ...any ides
« Reply #571 on: March 18, 2019, 10:14:38 PM »
Read the manual to make sure you complete the installation.
The blinking light in the bottom right is the reset LED. The reset button is the last one on the right of the toolbar at the top.
If you've completed the manual part of the installation, and click the reset button, everything should work.
« Reply #572 on: March 19, 2019, 01:33:06 AM »
complected the setup in the manual and the rest LED is out and i can jog the machine but still can't home the machine. i see max/min settings in the limit tab do they need to be entered to home  ?
« Reply #573 on: March 19, 2019, 06:38:06 AM »
Did you manually copy the macros into your profile folder?
Once you do that, you just click the Ref All button on the toolbar.
« Reply #574 on: March 19, 2019, 10:55:43 AM »
i did and i renamed the start/end macros. i have jog the machine around and i have checked proximity switches, emergency switch, tough off, all look good. maybe the macros are corrupted
« Reply #575 on: March 19, 2019, 10:58:49 AM »
I forgot to answer about the diagnostic screen.
The manual explains how to set it up. You have to drag it to the left twice.
Where did you copy the macros, and what is your profile name on the Diagnostics page?
The macros should be fine. What happens when you click the Ref All button? Is there a message on the screen at all?
« Reply #576 on: March 19, 2019, 11:38:37 AM »
Thank you Gerry i had copied it to mill and i'm using Oxzila, up and running can't wait to try out the tough off feature..
I am wondering your thoughts  on the 2017  I beleave it UCCNC ?
« Reply #577 on: March 19, 2019, 11:55:48 PM »
i bought the 2010 screen set yesterday...  i have it all installed and im still getting used to where everything is located..  im loving the look and feel, but first thing i need help with is, after touching off the touch plate, instead of rising 1mm and retouching the plate, the  z axis rises almost to the top of my z, and then slowly descends about 50mm, (doesnt touch the plate again) then moves to the fixed plate position and starts the fixed plate probing... i spent a few hours trying to figure out the problem, but i must be missing something, im pretty new to cnc, mach.. but i am competent enough have built the cnc and wiring.. so i must have a setting wrong somewheer
my units are in mm
z axis has about 100mm travel
Z- is toward table Z+ is up to homing switch
touch off block is 20mm (on top of table top, just untill i have it working)
probe works and signal shows active when the plate is touched
ive watched the set up videos at least 10 times
and read the instruction pdf cover to cove 3 times
any help would be amazing, thanks in advance
« Reply #578 on: March 20, 2019, 12:34:01 AM »
hi again Gerry , can you tell me what key is the Z jog ?
« Reply #579 on: March 20, 2019, 12:42:10 AM »
Garysb56
Z jog is page up / page down
