Hello Guest it is October 23, 2026, 04:10:35 PM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1460811 times)
Offline Jesus
  •  10 10
Re: Mach3 2010 Screenset - Now available
« Reply #440 on: April 15, 2016, 04:25:10 AM »
Ouch, I thought it might be. I will update the program. Thank you very much; I was already a little crazy with all this. I hope everything works properly updated. Today in the morning I'll try.
Thanks again Ger21
« Reply #441 on: April 15, 2016, 06:01:01 AM »
You need to be using at least a 3.42.********* version.
Offline Jesus
  •  10 10
« Reply #442 on: April 15, 2016, 06:12:15 AM »
Thank you very much, I've tried the update and I've seen some options that did not exist in the old version (Control brain ...)
Now I can put the plane clearance, lol just install it right now.
But for now I have a problem that I had, when I touch auto tool zero and the light goes on "probe", then Z axis rise to to up but don't stop in the right place.
The Z axis is not stopped all the way up until it touches the limits
Thank you very much again. I will continue investigating until everything is ok.
« Reply #443 on: April 15, 2016, 06:29:18 AM »
Are you using the parallel port, or a motion controller?
If motion controller, which one?
Do not use version 3.043.066
Go to the FTP site and get 3.043.062
http://www.machsupport.com/software/downloads-updates/#tabs-6
Offline Jesus
  •  10 10
« Reply #444 on: April 15, 2016, 06:32:34 AM »
A motion controller usb:  mach3 usb motion card (xhc)
This:
http://g02.a.alicdn.com/kf/HTB1uFM7KF*********XcEXpXXq6xXF*********q/XHC-MK4-font-b-CNC-b-font-Mach3-font-b-USB-b-font-4-Axis-Motion.jpg
Ok, I will download this version
thanks, thanks, thanks !!!
« Reply #445 on: April 15, 2016, 06:37:46 AM »
Some chinese motion controllers don't support probing properly. I'll send you an alternate set of macros later today that may work better. I don't have them here with me now.
Offline Jesus
  •  10 10
« Reply #446 on: April 15, 2016, 06:55:26 AM »
Thank you very much, then I will wait to try them
Offline Jesus
  •  10 10
« Reply #447 on: April 20, 2016, 08:54:54 AM »
Hi. Good afternoon Ger. First, thank you for all your help.
I am very happy because I can measure correctly, I think.
You can not imagine how much you've helped me.
I have just one last question. A while ago, I tried a file for the first time.
The measurement makes it right, but when beginning work says: "In Scripter Compile error. M6End.m1s"
But although the computer warn of this error the machine has successfully begun to do the job. But....
Changing the tool: after I change. The machine has not measured the No. 2 tool, the machine has continued to work directly without measuring.
The work done so far has been perfect. I have only that "little" problem.
Sorry, today I just wanted to thank you and good news. I wish my problem is small.
A big hello !!
« Reply #448 on: April 20, 2016, 09:14:03 AM »
I'll check this later today.
This is with the new macro I sent you?
Offline Jesus
  •  10 10
« Reply #449 on: April 20, 2016, 11:51:01 AM »
Yes, this happens using the new macros that you sent me.
Everything worked fine. The message worried me but until the change of the second tool everything was ok.
The only problem has been that. When I put the second tool spindle is operated and down directly to continue the work. The tool does not measure the milling cutter
